Old 04-21-2015, 08:16 PM   #131
psw757's Avatar
Originally Posted by captnrick3 View Post
Finally finished our kitchen back splash so it looks finished. Was simple and came out good.
Very nice, looks great!
psw757 is offline   Reply With Quote
Old 04-21-2015, 09:23 PM   #132
C8dnLegacy
Looks great!
2015 Legacy SR300 340KP
2015 Jeep Wrangler
cgpalmer is offline   Reply With Quote
Old 04-23-2015, 11:00 AM   #133
psw757's Avatar
Originally Posted by lrob View Post
I did and you beat me to the punch in getting the post. Lol. Here are the pics along with some other mods I worked on.
Attachment 74068Attachment 74069Attachment 74071
Thing works like a charm and has crazy suction. My wife loves it. Campers Inn did the install for me and did a great job.
Here is some other stuff I was doing
Attachment 74072Attachment 74073Attachment 74074
I also had an Carefree Colorado LED light strip put in under the awning that can display like 20 different light colors and can have all kinds of crazy patterns. Cool. When i get it lit up at night I will have to post some pics.
Do you have a picture of where they drilled up through floor? I'm thinking about tackling this myself.
Old 04-24-2015, 09:48 PM   #134
captnrick3's Avatar
Entry handle light
Originally Posted by psw757 View Post
If we don't have the wiring behind the handle, this could be a tricky install.
Installed an LED light in our entry handle today. A very simple install. Lower handle is even or slightly lower than the floor and the wires are hidden with no effort. Connected to the little entry step light so it works off the switch to that light. There is already a perfect path for the wires, the sensor wires for the electric step are already ran through a small hole.
ID:	75137   Click image for larger version
ID:	75138   Click image for larger version
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 04-25-2015, 08:00 AM   #135
dndnva's Avatar
Thanks! Good job! I knew someone would figure that out! Glad I didn't send my wiring kit/light back to Amazon.
2016 Legacy SR340 KP (340HP, 2500 Allison)
Toad: 2013 Wrangler Unlimited
dndnva is offline   Reply With Quote
Old 05-02-2015, 08:46 AM   #136
psw757's Avatar
So I talked to forest river about installing a pullout fridge freezer in either the very forward passenger side compartment or the one aft of the wheel. Was basically told it couldn't support the weight but when I thought about it I haul a cooler full of beer water and ice any way which I'm sure is even heavier.
Thoughts anyone? This isn't the easiest to figure due to having to clear the door lip.
Old 05-02-2015, 11:30 AM   #137
captnrick3's Avatar
I just went out and looked at both those compartments... I have a hard time seeing weight as an issue, we all carry heavy "stuff" in compartments. Not sure if you can find a fridge that will clear that lip or not, I think that is the only major issue. Not hard to find an electric line anywhere on the coach.
2015 Legacy 340KP
2012 Wrangler Sport
Old 05-02-2015, 12:01 PM   #138
psw757's Avatar
I think I measured the lip to be around 4".
The fridge would go on one of them raised pullout trays which I believe some raise the floor 4-6 inches.
I'm just sick of lugging ice around and having to replenish all the time.
I have to figure this out!
Old 05-02-2015, 08:24 PM   #139
captnrick3's Avatar
Fresh water tank fill
Did a little plumbing today and installed a valve to fill the fresh water tank via the city water connection. Plumbed so the tank also fills with filtered water as well. Pic below. Labeling looked pretty good until I took the pic, I can see that getting redone tomorrow.
2015 Legacy 340KP
2012 Wrangler Sport
Old 05-04-2015, 05:49 AM   #140
psw757's Avatar
Anyone install the hinges/struts on the under bed storage yet? Is there enough support under there for that, any pictures?
Definitely would like to do this.
modifications
