Old 06-20-2015, 05:49 PM   #191
lrob's Avatar
I haven't used it yet, but I will here in about a week or so. I bought this because I had to park at a campsite recently and the drain was uphill. Complete nightmare! Took so long for me to drain it and I had to maneuver the hose with contents inside to try to get the hose to drain. That's when I decided not to have this problem again. I can't control the drain, but I can control how I get it to it.
2014 Legacy SR300, 340BH
Toad: 2011 GMC Acadia
" On the go to see something amazing"
- Psalm 107:23-24
lrob is offline   Reply With Quote
Old 06-22-2015, 10:22 AM   #192
Originally Posted by conceptumator View Post
So do you empty your tanks into your sewer at home? The ability to do that would be my main draw. Would also be good, I guess, if I was camped close to the dump station and didn't have sewer at the site. Thanks for the info. Enjoy!
Correct, I have a 1" PVC line that runs from my RV port to my septic system. O my intention is to install a Sani-con and use that to macerate and pump the waste to the septic system.
foretm is offline   Reply With Quote
Old 06-22-2015, 10:26 AM   #193
Originally Posted by aeroshots View Post
I have one of these and like it so much I've transferred it from and to the last two "campers" we've owned.
--It has been used to pump into my home septic.
--Around a broken down rig parked at a dump station.
--Less of a trip hazard on the left side of the rig.
--More parking options at the less than ideal/level camp spot.
--As stated, pump up hill.
--Stows neater and easier and cleaner.
--A little known feature is transfer between full gray into less full black tank.
Yep, it is going into my new "camper" soon. There are a few models so read the functionality of each before getting one if your thinking this route.
Regarding the last feature, was that accomplished by pumping into the toilet after routing the hose through a window or something similar? That is a feature I had not thought of.
Old 06-22-2015, 10:45 AM   #194
Looking forward to some feedback on it... Only thing I was concerned about was the 15 minute continuous usage. See this website and the quote from about 3/4 of the way down the page in the "Pump Precautions" section.
RV Sani-Con: Installation Information for our RV Parts and Accessories
"The dc motor is suitable only for intermittent duty; do not run the pump for more than 15 minutes continuously"
If we have 44 gallons of black and 44 gallons of grey in Legacy, that should equate to 88 gallons and approximately 9 minutes of run time assuming completely full tanks and the "up to" 10 gal/min.
Aeroshots, can you comment on this, have you ever had any issues with the duty cycle of the pump? Have you run it over 15 min? What's the longest run you've done? The highest elevation change?
Old 06-22-2015, 12:10 PM   #195
aeroshots's Avatar
O - no, nothing like that. Assuming gray and black tanks are close to level with each other (past campers were ) the head pressure from full gray tank will provide flow into less full black tank.
1. Open gray valve
2. Open black valve
3. Listen for fluid flow
4. When flow stops, close black then gray valves.
The hoses stay connected with the permanent mounted system.
..2016 Legacy 340KP SR340, 10,500 Miles..
aeroshots is offline   Reply With Quote
Old 06-22-2015, 12:19 PM   #196
aeroshots's Avatar
Aeroshots, can you comment on this, have you ever had any issues with the duty cycle of the pump? Have you run it over 15 min? What's the longest run you've done? The highest elevation change?[/QUOTE]
Never any duty cycle issue. I've run it for a good 15 minutes several times. 3 feet elevation change as a guess.
Keep in mind that the head pressure from each tank will be helpful to the motor. I pulled it out of the last camper a year ago, but as I can remember it has a bypass of sorts that let's the gray water flow without using the pump.
Old 06-26-2015, 07:07 PM   #197
lrob's Avatar
Just finished after 4 hours washing and waxing my rig. You can see the reflection of my house it's such a deep glossClick image for larger version
Name:	ImageUploadedByForest River Forums1435363604.559393.jpg
- Psalm 107:23-24
Old 06-26-2015, 09:47 PM   #198
psw757's Avatar
Just finished after 4 hours washing and waxing my rig. You can see the reflection of my house it's such a deep glossAttachment 81231
Looks great. Did mine last week and used rejex and that stuff is awesome.
psw757 is offline   Reply With Quote
Old 06-30-2015, 09:45 AM   #199
ernest917's Avatar
psw757...
You CAN add a pullout fridge freezer.... Ck this out -
Name:	ImageUploadedByForest River Forums1435675394.053683.jpg
ID:	81730Click image for larger version
Name:	ImageUploadedByForest River Forums1435675429.788859.jpg
ID:	81731Click image for larger version
Name:	ImageUploadedByForest River Forums1435675455.270631.jpg
ID:	81732Click image for larger version
Name:	ImageUploadedByForest River Forums1435675479.965590.jpg
ID:	81733Click image for larger version
Name:	ImageUploadedByForest River Forums1435675514.221990.jpg
We LOVE ours...
ernest917 is offline   Reply With Quote
Old 07-01-2015, 08:58 AM   #200
lrob's Avatar
Originally Posted by psw757 View Post
If anyone is looking for a exterior front window shade and side window shade we bought the MagneShade and it works great, easy to install. They should have the template on file so no need to do all the measurements.
just got my Magne Shade in the mail. Thanks for the measurements that you gave them. Looking to do the fitting and install tomorrow.
- Psalm 107:23-24
modifications
