Yes. All the wires to the back of the dash were in looms. So rather than pull them apart, I spliced and routed them from behind the dash panel, above the steering column, into the hole in the front end of the driver's side panel. Same with the leveling control panel (two wires). It's in the loom with the trans wiring, so I spliced it in and routed it to the front dash panel. It's about 5 feet between the two points.
