Old 11-13-2015, 08:24 AM   #271
psw757's Avatar
Has anyone considered installing a power cable reel? They make some lower profile ones now but not sure if it would fit correctly.
psw757 is offline   Reply With Quote
Old 11-13-2015, 09:19 AM   #272
Blacknchromehd's Avatar
Reel
I considered installing a outside male outlet like you see on the 5th wheel trailers and then using a cord stored inside. Trying to get that big cord into the compartment takes more time than anything else...I did see one mounted inside the rear section where the radiator is located...plenty of room in there...
Blacknchromehd is offline   Reply With Quote
Old 11-13-2015, 11:08 AM   #273
psw757's Avatar
I'm not a big fan of the external plug that you see on the fifth wheel.
I think a powered reel would be nice, I think I'm going to investigate this more.
Old 11-29-2015, 07:42 PM   #274
aeroshots's Avatar
Soundbar
ID:	95243Moved the sound bar from inside to the outside TV location. Wow, what a piece of junk for a sound bar. I've got a good one on the way for the inside and will probably replace the outside one in the future.
..2016 Legacy 340KP SR340, 10,500 Miles..
aeroshots is offline   Reply With Quote
Old 01-26-2016, 12:49 PM   #275
dndnva's Avatar
Towel rack installation
Originally Posted by captnrick3 View Post
I got rid of that picture day one, replaced with a mirror just to cover the area and installed brushed nickel towel racks. That area just proves RV decorators/designers never used an RV before.
Captnrick/Irob,
Did you use the screws that came with the towel racks or use shorter screws or molly bolts? I bought the one IROB installed but I am worried about putting those long screws in the wall....actually terrified they will pop out the side of the RV! Did you find studs or just center and use plastic screw sheaths?
Thanks...been putting this off too long and just need to do it!
2016 Legacy SR340 KP (340HP, 2500 Allison)
Toad: 2013 Wrangler Unlimited
dndnva is offline   Reply With Quote
Old 01-26-2016, 05:11 PM   #276
lrob's Avatar
just go to the HW store and get some 1/2" sheetrock screws. You don't need to put them all the way into the wall as the head needs to stick out so that it can hang. That will do the trick. I used 2 one on each end and then used 3M hanging tape on the back. Worked great !
2014 Legacy SR300, 340BH
Toad: 2011 GMC Acadia
" On the go to see something amazing"
- Psalm 107:23-24
lrob is offline   Reply With Quote
Old 01-27-2016, 12:08 AM   #277
captnrick3's Avatar
Originally Posted by dndnva View Post
Captnrick/Irob,
Yep, what Irob said. The walls are at a minimum 1 1\4" thick and substantial enough that molleys or anchors are usually not necessary nor is finding a stud which would be aluminum anyway.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 02-08-2016, 08:19 AM   #278
aeroshots's Avatar
Cable Routing
Moved some electrical cables so the engine access cover could be removed.
ID:	99148   Click image for larger version
ID:	99155   Click image for larger version
Old 02-08-2016, 08:34 AM   #279
How do you Normally gain access to the Engine bay? Where have you traveled to have a Engine in that condition on a 2016 unit? Youroo!!
Old 02-08-2016, 08:45 AM   #280
aeroshots's Avatar
Normal access to the top of the engine is through the shown access panel. Day to day servicing is from the exterior rear. Someone at the factory routed two 120V cables across the panel making it impossible to remove.
modifications
