05-09-2015, 08:58 PM
#161
Legacy mods and improvements
I only use what came with the mudflap, and one link for each side. Hangs perfectly when the coach is aired up and there are no problems with the muffler. You shouldn't have to cut a flap to make it work.
2014 Legacy SR300, 340BH
Toad: 2011 GMC Acadia
" On the go to see something amazing"
- Psalm 107:23-24
05-09-2015, 09:02 PM
#162
New install. Keyless entry. Works great. Here are a few pics. Tricky to install, but cool feature.
- Psalm 107:23-24
05-11-2015, 10:43 AM
#163
You folks are driving me crazy by posting all these great mods .... but I can't do any of them cause I haven't taken delivery yet. Not a problem after today as I pick my RB up tomorrow. First upgrades will be Progressive Industries hardwired power monitoring system, roof vent covers, and screen door grille. Then can start in on some of the other mods seen here. Thanks for sharing.
-DrJAG
2015 Legacy 360RB with 2013 CRV toad. Retired USAF.
05-11-2015, 11:01 AM
#164
Congrats DrJAG!!! Hopefully plan to join you in a year or so as a proud new owner. Start a new thread when you get it... love to hear more about it.
05-11-2015, 12:40 PM
#165
7 Year Class A RV'er
DrJag: Sounds dumb, but when you pick it up, check the tailpipe and chrome exhaust tip. Mine (and some others) was delivered missing the last 3' of exhaust system and the tip. Didn't notice it for a week after we got it home! Sitting here right now waiting on them to get it installed. Congrats - enjoy!
2015 Legacy SR340 360RB
05-11-2015, 01:06 PM
#166
Thanks for the heads up. I'll be sure to check the tail pipe although I think I remember seeing chrome exhaust tip when looking at the rv before deciding to buy it. Dealer found several items that needed to be replaced. ...transfer switch, bunk motor, cabinet doors to name the major ones. Also all 3 TV had scratches on the frames and are being replaced.
-DrJAG
05-12-2015, 09:59 AM
#167
Originally Posted by lrob
Great job, thanks for posting.
2015 Legacy 340KP
2012 Wrangler Sport
05-12-2015, 10:34 AM
#168
Would you mind providing the specific make/model of the keyless entry and any notes on the tricky install?
05-13-2015, 01:33 PM
#169
I bought the Bauer EM Model. This one works for motorized RVs. it has the dual pin latches that are required by law.
Here is the link:
Bauer Products - Bauer EM
list price is 399.00 but you can get it way cheaper than that. I bought mine from eBay for 219.00 including shipping. Well valued upgrade.
The tricky piece of this installation is that you have to remove the baseplate from the door along with the entire lock to get the lock out. It will not release unless you do it.
Next tricky piece is after you do the install based on the video instruction, you will have to shave the door trim on the outside to get the handle to engage with the strike plate. If you do not shave it, the door hits against the trim and will not close. I used a Roto Zip with a diamond tile bit to shave the metal down on the door frame so that the door could engage with the strike place.
Final tricky part is that you have to remove the inside door trim to get to the spacing gap between the door and the RV. This is where the strike plate lives. This is easy as you remove the button covers and the screw is underneath. You have to remove the original strike plate and replace it with the Bauer edition. It is a bit tough to get out by prying the gap open with a screwdriver as the video suggests--in fact does not work all that well. i used a screwdriver and a hammer to force the strike plate out after removing all that other stuff. Once it is out, it is a breeze to put the new one in place and tighten down. I took a few more pics and will post so that you can see what I am talking about.
- Psalm 107:23-24
05-16-2015, 10:49 AM
#170
First big mods for me: Progressive Industries power management system and 3 roof vent covers.
-DrJAG
05-17-2015, 08:04 AM
#171
Here is the link:
Here are the pics as promised:
- Psalm 107:23-24
05-17-2015, 02:12 PM
#172
Irob, saw the pic of your screen door grille. How did you attach the bottom right corner in light of the step switch magnet being in the way?
-DrJAG
05-17-2015, 02:56 PM
#173
Velcro. You have to move the bottom over so that it fits within the screen engaging with door frame. The screw won't work so I attached some Velcro there that was a bit wider than the edge of the frame of the screen and attached it. Used an exacto knife to trim it so the screen closes as it did before I put on the guard.
- Psalm 107:23-24
05-17-2015, 03:04 PM
#174
Originally Posted by dndnva
Thanks! Good job! I knew someone would figure that out! Glad I didn't send my wiring kit/light back to Amazon.
Here are the pics about attaching the sweep and where it works best.
- Psalm 107:23-24
05-17-2015, 03:06 PM
#175
Added Bluetooth to the Jensen radio. Works great and is easy as pie to install
Can play music without the wires.
- Psalm 107:23-24
05-17-2015, 03:08 PM
#176
I use surge guard but that looks sweet! Nice work!
- Psalm 107:23-24
05-17-2015, 03:38 PM
#177
Thanks! Will give velcro a go.
-DrJAG
05-17-2015, 03:56 PM
#178
- Psalm 107:23-24
05-17-2015, 05:42 PM
#179
Thanks for the pic.
-DrJAG
05-29-2015, 06:38 PM
#180
Originally Posted by psw757
Odd, we have about 3.75 inches off ground. We do get a slight rub of muffler pipe on the most uneven of surface . You should have a d-ring at receiver 2-3links and the flap hook. Cut the links with bolt cutter. Don't worry about a slight pipe rub. I've seen a lot of coaches with pretty rough looking flaps from that.
Here are some more photos of my rear sweep install. Close up on the muffler
Mine is a buckled due to my air bags that did not fully inflate and my flap was resting against the muffler. Bad solenoid. I have no issues with rubbing.
- Psalm 107:23-24
