Old 12-28-2017, 04:06 PM   #1
Legacy Q's for new owner
We dry camp often, i have a little honda 3000 generator to keep the batteries up, without running the big on board generator. However plugging it into the shoreline does not seem to charge the house batteries. Am I missing something? I don't run anything on the little generator, just want a trickle charge. My thought is if i connect the batteries to a seperate charger and plug that into the little generator it would work. My fellow campers do this on their 5th wheels and and have no issue, but myself in the 2014 legacy and another family in another class A have the same issue.
Also thanks for adding me to the forum, I've posted a pic of our rig at Catalina State Park in Tucson AZ yesterday.
P
Name:	catalina state park RV.jpg
lazyPAZ is offline   Reply With Quote
Old 12-28-2017, 05:01 PM   #2
psw757's Avatar
P
Do they charge from a 50/30amp shore power service or the big generator?
Iím thinking it may have to do with bypassing the magnum converter/charging system when hooking up to an external generator.
psw757 is offline   Reply With Quote
Old 12-28-2017, 05:44 PM   #3
Yes they charge from both the big generator and a 30A shore line.
Old 12-28-2017, 06:28 PM   #4
psw757's Avatar
Then that means the normal operating of the system is working correctly.
How many amps is the Honda putting out when your using it and are you plugging into it or running something directly to batteries?
Old 12-28-2017, 06:33 PM   #5
Thanks for your reply, the generator is plugged into the shore line, it is rated for 21.7a at 2600w and 25a at peak output 3000w.
Old 12-29-2017, 01:29 PM   #6
7 Year Class A RV'er
Any particular reason you don’t just use the onboard diesel generator? Not really very loud and a lot more fuel efficient. When our power was out after the hurricane this summer we moved into the RV in the driveway and stayed four days and nights with the generator goingfor both AC units, fridge, TV and ran a cord to a freezer two fridges in the house. Couldn’t believe we only used like 25 gallons of fuel total for the four days.
2015 Legacy SR340 360RB
Old 12-29-2017, 01:42 PM   #7
Originally Posted by conceptumator View Post
Any particular reason you donít just use the onboard diesel generator? Not really very loud and a lot more fuel efficient. When our power was out after the hurricane this summer we moved into the RV in the driveway and stayed four days and nights with the generator goingfor both AC units, fridge, TV and ran a cord to a freezer two fridges in the house. Couldnít believe we only used like 25 gallons of fuel total for the four days.
I will if running the a/c etc, but seems like a waste to charge the batteries. Plus it puts less hours on the unit.
Old 12-31-2017, 09:11 AM   #8
jonj15546's Avatar
P
It should charge the batteries if you plugged into shore power. You need to make sure the system is cut on. Click image for larger version
jonj15546 is offline   Reply With Quote
Old 12-31-2017, 10:48 AM   #9
psw757's Avatar
I read through the original post again and it got me thinking about this again. It works fine off the coach generator and the coach shore power cord.
It isn't or doesn't appear to work when running the Honda generator which is powering a small trickle charger which is connected directly to batteries.
Is there a chance that it could be charging or possibly not at enough of a rate to exceed whatever power you may be using during this type of setup.
My other thought is that you are totally bypassing the Magnum charging/inv/conv system and it may not be able to accurately monitor the batteries state.
Maybe try and get a independent charge reading (not what the magnum display indicates) then run your setup for a bit and take another reading.
Other than that not sure what else to look at.
Old 12-31-2017, 06:07 PM   #10
jonj15546's Avatar
Yea hooking up directly to the batteries should charge them bypassing the magnum system.
