Old 04-20-2019, 03:53 PM   #1
Leveling before and after slides areout?
We have a FR Legacy SR300. We auto level before putting out the slides, as recommended by the manual. After the slides are out, it's no longer level. Is it harmful to auto level again after the are slides out?
Thanks,
Gabe
Soonerdoc is offline   Reply With Quote
Old 04-20-2019, 04:25 PM   #2
CAT-RN's Avatar
I would just bump it up to level on manual. Lot less movement on the system.
Russell
CAT-RN is offline   Reply With Quote
Old 04-20-2019, 04:29 PM   #3
Herk7769's Avatar
No auto-level here and I don't like to move the camper with the slides out.
I level with the slides in. Only very infrequently does the camper settle after setup.
Herk
HAM CALLSIGN - KC3FFW
Old 04-20-2019, 04:31 PM   #4
Georgia Rally Coordinator
aceinspp's Avatar
Herk
X 2 Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 62
Old 04-21-2019, 12:39 PM   #5
The old Wicked Kitty always settles a bit. The back stabs a lot of times need a tad adjustment. The fronts never since I always set the side opposite the slides just a tad higher.
Portagie1968 is offline   Reply With Quote
Old 04-21-2019, 02:35 PM   #6
Lacey's Spring, AL
formerFR's Avatar
your levelers are perfectly capable of 'leveling' the rig, even with the slides out, as we've done this many times... but using the 'manual' method provides a quick and easy way to add a little to whichever side you need to... I always use Manual mode now, anyway...it's just easier for me to do it than wait for the system to jump around and finally level it, but leaving it much higher than I can on my own.
Also, drop your air bags before you do. Your coach will sit much lower, with a lower center of gravity, and the legs don't have to travel near as far, either. Much less movement is noticed in the coach when moving around, also.
When you get ready to leave, let the bags air up, then use the 'auto retract' button on the levelers... many times the legs are then already off the ground and they'll be no 'bumping' down as they move up.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 04-21-2019, 07:41 PM   #7
I set the rv 1 bubble high on the slide side. Once the slides are out it is level.
RStormC is offline   Reply With Quote
Old 04-21-2019, 08:52 PM   #8
Traveling Two
jerryliving's Avatar
Me too
jerryliving is offline   Reply With Quote
Old 04-22-2019, 12:59 PM   #9
AKA: 'tiredTeacher
awellis3's Avatar
Me three.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
leveling, slide
