Old 06-27-2016, 08:45 AM   #11
aeroshots's Avatar
Guessing that you have it fixed and no longer have a need for ideas from others.
aeroshots is offline   Reply With Quote
Old 06-27-2016, 11:58 AM   #12
jack pad fix
I received a reply that stated the pad is held on by a hex bolt underneath the pad. Of course you need a air impact wrench to loosen. Problem solved
necasperaterrent is offline   Reply With Quote
Old 06-27-2016, 12:01 PM   #13
aeroshots's Avatar
Very cool. Did you weld or replace the pad? Please share the source of the pad if placed. Thanks
bent
