Old 05-22-2016, 12:14 AM   #1
lifting jack bent
Has anyone replaced pad on 2014 Legacy? How is it done.
necasperaterrent is offline   Reply With Quote
Old 05-22-2016, 08:18 PM   #2
aeroshots's Avatar
That stinks. Is it just the pad that is damaged or the jack itself?
..2016 Legacy 340KP SR340, 10,500 Miles..
aeroshots is offline   Reply With Quote
Old 05-23-2016, 12:15 AM   #3
Pad repair
No, just the pad. I believe it is held in place by large allen bolt up under the center of the pad?
Old 05-23-2016, 09:16 AM   #4
aeroshots's Avatar
Can you post a photo of the damage? That might get you some suggestions on repair or replace.
I'm modifying my headlights when parts arrive in a couple days. I'll crawl under and take a close look at the jacks for clues then.
Old 05-23-2016, 10:07 AM   #5
psw757's Avatar
What kind of fix do you have for headlights?
psw757 is offline   Reply With Quote
Old 05-23-2016, 10:11 AM   #6
aeroshots's Avatar
Don't want to hijack this thread. If successful I'll post over on the headlight thread. If successful. 😃
Old 05-23-2016, 10:20 AM   #7
picture to follow...thanks
Old 05-23-2016, 02:39 PM   #8
captnrick3's Avatar
Yes. I bent one last summer really bad, totally my fault by setting it down over a hole and putting way too much pressure on it. The single hex bolt on the bottom can be removed with an impact wrench. There is no way to hold the shaft of the hydraulic ram. Comes off really easy that way.
Just to be sure, I called Equalizer to ask if there was any issue with the ram shaft turning some while removing the foot. Person I spoke to was very helpful and told me the impact was the only way to go, and a little shaft rotation was OK. I bought a spare foot, but was able to straighten and then strengthen the one I had and reinstall. Don't remember how much the foot was, but I did not find it bad at the time.
Hope that helps.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 05-29-2016, 07:40 AM   #9
aeroshots's Avatar
Update?
Old 05-30-2016, 06:06 PM   #10
further info
pictures to follow
bent
