Old 05-13-2018, 09:28 AM   #1
jvenditte's Avatar
Line 2 brownout
Camping in 100 degree heat. Checked my power control panel in power management. Line 1 reads 114v, 13 Amps, 26%. Line 2 reads brownout, 78 volts 1 amp, 2 percent.
Everything seems to be working fine. Do I have an issue? What does line 2 brownout mean?
jvenditte is offline   Reply With Quote
Old 05-13-2018, 09:34 AM   #2
If there is anything substantial on line 2...yes, you will have a problem. I would check the pedestal and see if the voltages match what you are reading. Should have 120 volts between neutral and ground on both legs! If you don't, whatever is on leg 2 is susceptible to burning out, especially an AC unit.
Hopefully, your "power management" system will have disconnected line 2.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 05-13-2018, 10:04 AM   #3
Like Scott said, check the pedestal. If the problem is there report it immediately. If not check where your cables connect to your converter (with power off). Most likely a loose connection somewhere. Could easily lead to overheating and a fire.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 05-13-2018, 10:19 AM   #4
jvenditte's Avatar
Thanks, line two is running the back air conditioner. I shut that off and nothing else seems to be drawing current.
Old 05-13-2018, 01:35 PM   #5
jvenditte's Avatar
Technician indicated the air conditioner could not operate on a 78v line. Suspects the monitor to be giving an incorrect reading. Suggested I reboot. I have both lines getting 120v at the source but when I read from the coach, it shows the drop to 78v on line 2.
Old 05-13-2018, 02:05 PM   #6
It sounds like youíve got a bad connection between the source and the coach. With any load, it will heat up at that bad connection. If you verified the 78 volts with a separate meter, your monitor is probably not wrong.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 05-13-2018, 02:07 PM   #7
If the AC is running, you don't have 78 volts. Now the problem is to find out why the panel thinks you do?
2015 335DS
Old 05-13-2018, 06:53 PM   #8
jvenditte's Avatar
Flipped the breakers at the pedestal. Seemed to fix the problem......
Old 05-13-2018, 06:57 PM   #9
I think I would move to another camp site ASAP.
