It is the Bauer EM. I bought it from Amazon. Pretty straight forward installation. Had to cut a little square notch on the outside of the door to accommodate the bottom of the latch handle hinge. Also had to thin the inside door panel some. In this photo, you can see the square notch I cut on the outside door panel. Unfortunately I did not take a pic of the area I thinned in the inner panel. If you look above the notch to the inner part of the inside door panel, I thinned some of the wood away from the area in the shadow. I was able to use the existing strike plate so did not have to deal with removing it and installing the new one. Thus far pleased with it, but haven't had it very long. The Bauer EM has pretty good reviews when I Googled it.
Note the two pins shown in this pic just barely missed hitting the door frame when closing the door.
2015 Legacy RB, 2013 CRV toad. Retired USAF. Sent from my iPad using Forest River Forums
