Old 06-15-2018, 11:39 AM   #1
Sharkey Berkshire Owner
No cigarette lighter charger?!!!
Hello,
I was parked next to someone with a new 2018 Legacy (39'). I provided him with many helpful tips and suggestions, but when he bought his TPMS it has a cigarette lighter power source, however, he only has 2 USB connections where it appears a cigarette lighter used to be! Are there any hidden cigarette lighter connections he can use?
TIA
CPOSharkey is offline   Reply With Quote
Old 06-15-2018, 11:45 AM   #2
rsdata's Avatar
TST TPMS uses USB power...
does his cig lighter plug disconnect from the TPMS display? Does it have the standard small USB connector to the monitor? Just get the proper adapter for USB if it does...
“Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 06-15-2018, 11:50 AM   #3
It does not. I did locate a converter cable on Amazon, but cannot imagine there would be NO cig lighter available; my 2017 Berkshire has 3!
Thanks.
Old 06-15-2018, 01:19 PM   #4
Lacey's Spring, AL
formerFR's Avatar
the 'ol' cigarette type 12v power source is quickly becoming obsolete, so few use them now that USB is becoming the standard since that's what most folks demand now.. Most of us would hardly even know what 'cigarette' lighter you're referring to! : )
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx,
100,000+mi since '14, US, Alaska, Canada, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 06-15-2018, 07:57 PM   #5
Tombsy's Avatar
It's easy to add power ports or USB outlets, there are many combo's you can pick.
https://www.ebay.com/bhp/12v-usb-outlet
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 06-16-2018, 03:02 PM   #6
Delco Bobby's Avatar
My TST 507 came with a cig lighter for power with another cord for hard wiring.
Are you ssying that I could be using a USB with the small USB connector on one end? The difference in voltage doesn't matter?
I will be happy if that is true.
Delco Bobby is offline   Reply With Quote
Old 06-16-2018, 05:18 PM   #7
Tombsy's Avatar
Yes if the lighter plug for the TPS has a regular usb that the cord plugs into then it's fine, the other end is a micro usb. The step down from 12v to 5v is done in the plug.
It would look something like this
Brian
Old 06-16-2018, 05:43 PM   #8
Commercial Member
TireTraker can be charged with USB cable but I only need to charge the monitor once every few days. I think the Monitor is good for 24+ hours on a full charge.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling)@ FMCA in Tuscon, AZ and Syracuse NY in 2020
Tireman9 is offline   Reply With Quote
Old 06-18-2018, 01:17 PM   #9
My new 2019 Rockwood 2606 WDS has a cigarette lighter type charger and two USB's on one of the nightstands plus there are two more USB's on the stereo system. Whoever designed it, I'd like to thank them!
NH Traveler is offline   Reply With Quote
Old 06-18-2018, 02:05 PM   #10
My TST does not have any sort of USB connection..
2017 Dynamax REV 24RB
2018 Ford F-150
light
