Old 09-21-2016, 06:12 PM   #1
Oil change.
I am at auto parts and need to verify what oil is required for the Cummings coach motor. I don't have manual with me. Help!
Englund is offline   Reply With Quote
Old 09-21-2016, 06:13 PM   #2
Can we run Synthetic?
Old 09-21-2016, 06:46 PM   #3
I was considering Shell Rotella T 15W-40 Heavy Duty Diesel Oil, I think you can get 5 Gal at Walmart for under $70.00. I'll go grab the book and see if there is a recommendation.
2014 FR Legacy
2006 Jeep Unlimited
hbjoe3 is offline   Reply With Quote
Old 09-21-2016, 07:10 PM   #4
The book says use API Service 15W-40 with a CES20081 rating, or a API rating of CJ-4/SL.
"Use of "synthetic engine oils" (those made with API group 3 or group 4 base stocks) is permitted, subject to performance and viscosity limitations of petroleum (mineral) based engine oils. The same oil change intervals that are applied to petroleum (mineral) based engine oils must be applied to synthetic oils." (ref: Owners Manual ISB6.7 CM2350 B101)
There is more info based on weather conditions that you may need to consider.
FYI Our Legacy is a 2014
2014 FR Legacy
2006 Jeep Unlimited
Old 09-21-2016, 07:35 PM   #5
Oil Capacity?
Anyone know the engine oil capacity? I can't find it in the book.
Thanks.
2014 FR Legacy
2006 Jeep Unlimited
Old 09-21-2016, 09:40 PM   #6
7 Year Class A RV'er
Three gallons (12 quarts). Rotella seems to be the recommended oil. They sell it at Walmart in one gallon containers, too.
2015 Legacy SR340 360RB with 2014 Wrangler Unlimited Toad
Gigi, Poppy and Sadie the Jack Russell (all 14 lbs of her)
Old 09-21-2016, 09:45 PM   #7
Ok thanks. I am Going with the Rotella type t. Synthetic
Old 09-22-2016, 09:17 AM   #8
Jim34RL's Avatar
Valvoline Royal Purple 15W-40 Oil is the recommend product for Cummins engines. The oil containers even have the Cummins logo on the front label. I can usually find this on sale between $10.60 TO $11.50 a gallon depending on which store has the oil on sale. It is also recommend that you change your oil filter at every oil change.
Please do not buy the cheap oil filters that the parts stores sell, buy the correct Fleetguard filters for your engine. Your engine will thank you in the long run. The Fleetguard filters are engineered for the Cummins engines. The filters provide the correct filter media, inlet/outlet hole pattern, Belleville spring washer and bypass to name a few items that will provide the proper oil filtration and circulation of the oil to your engine.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 09-23-2016, 10:57 AM   #9
I used 4.5 gallons when changing the oil and filter. I have run the engine and checked and rechecked. Is this the same amount everyone else is requiring?
Old 09-23-2016, 11:17 AM   #10
Iwannacamp's Avatar
If the oil meets OEM specs... I would always pick the synthetic oil. Stay with reasonable intervals and enjoy a long and healthy engine life and improved economy. My only recommendation is to pick an oil and stay with it(others have different input).
2017 Puma 297RLSS
