Old 02-29-2016, 09:55 AM   #1
aeroshots's Avatar
Oil Drain Valve
Has anyone installed and used one of these? I'm about to push the purchase button. Pretty sure this specific one is the correct fitment.
Robot Check
..2016 Legacy 340KP SR340, 10,500 Miles..
aeroshots is offline   Reply With Quote
Old 02-29-2016, 10:04 AM   #2
hammer55's Avatar
seen them posted before, some have, I was thinking on getting one, the drain on the F-53 chassis is right over the front beam, would be nice to connect a hose to keep it all clean,,,
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 02-29-2016, 10:15 AM   #3
W5CI's Avatar
I ran ran that for years on two different Kenworths for probably 3 Million miles without any trouble. I will put one on my RAM Cummins when 1st oil change comes up
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is online now   Reply With Quote
Old 02-29-2016, 10:19 AM   #4
aeroshots's Avatar
I've decided to do it, just need to confirm fitment on my Cummins 6.7 340hp Legacy. Looking forward to a more controlled and cleaner oil draining.
Old 02-29-2016, 10:25 AM   #5
Jim34RL's Avatar
If you have the factory oil pan than yes it will fit. I am using one on my 6.7L in my 2008 Ram Mega Cab. I purchased my valve from Geno's garage. They sell the 18mm valve for $21.95. Geno's part number is FTV-104A; this will fit all model years from 2002 to 2016.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 02-29-2016, 10:34 AM   #6
aeroshots's Avatar
I'm not sure if my Legacy motor home uses the same oil pan as that on the RAM pick up. The fumoto website shows an 18m and a 22m for the 6.7 Cummins.
Old 02-29-2016, 11:00 AM   #7
Jim34RL's Avatar
The 22mm drain valve is for the older 5.9L engine built between 1994 and 2001; per Geno's Garage.
If the engine is painted red and the oil pan is painted red too than you have the same oil pan as the Ram trucks.
I was on a factory tour with Turbo Diesel Register in 2013, to the CMEP plant in Columbus IN were the 6.7L engine are built. All 6.7L Engines are built on the same line, the only difference is that the OEM engines for motor homes are painted Red. The engines for the RAM trucks are not painted but Clear Coated instead. The biggest difference is the software that is loaded into the ECM that controls the fuel input and other parameters.
Jim W.
Old 02-29-2016, 11:45 AM   #8
DaveSchwartz's Avatar
I've had a Fumoto on my Duramax for 10 years now with absolutely no trouble. Only thing is that with a significantly smaller opening than pulling a drain plug you really need to warm up the oil before opening the valve... 10 qts of cold 15w40 takes forever to drain.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 02-29-2016, 12:02 PM   #9
TURBS's Avatar
We have 3 fleet trucks that have them, all good here!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-29-2016, 01:52 PM   #10
aeroshots's Avatar
Cool beans. Thanks everyone for the replies and specific information.
drain
