Old 04-08-2016, 02:53 PM   #1
Blacknchromehd's Avatar
Rear Camera
Great.....first time out of the garage from this winter and thought the screen for the rear was simply fogged over....then today check again and she is black...sides work fine...
Mike at FR told me how to look at the plug and could be a simple bad camera which he said no problem its bad...anyone else have this issue..
Blacknchromehd is offline   Reply With Quote
Old 04-08-2016, 03:04 PM   #2
captnrick3's Avatar
Not me, anxious to see what the problem is with yours. Mine work fine now, but I don't know much about them or how to troubleshoot.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 04-08-2016, 06:44 PM   #3
Pulled out the camera with the help of Mike from the factory's suggestion.....found a very long cable and the connection was corroded....cleaned it and believe it or not works just fine....
Old 04-09-2016, 03:40 PM   #4
captnrick3's Avatar
Thanks, I will keep that in mind just in case. Surprised it got corroded inside the the rear cap. Who knows.
2015 Legacy 340KP
2012 Wrangler Sport
Old 04-09-2016, 10:30 PM   #5
From what I can tell the cable must lay on top of the engine compartment....was easy to get it out and nice to be able to fix it on my own...
Old 04-11-2016, 08:57 AM   #6
Cable
As mike told me its a long cable and will allow me to pull it out to work on it...I looked up inside the rear cap from the floor so see all the cables and such...I guess like anything moisture can get in there...
Old 04-12-2016, 10:16 AM   #7
ScottPM's Avatar
too bad you can not move the camera up and down. my last coach you could and made hooking up to a trailer nice and easy. Thanks on the heads up and the cable I will be looking at mine
Scott Menard
2015 Legacy 360 RB
ScottPM is offline   Reply With Quote
Old 04-12-2016, 11:34 AM   #8
trailer view
Scott...Actually there are set screws on the camera that I plan to rework the bracket so I can look down just a tad more when I have the trailer mounted...
Old 04-12-2016, 11:51 AM   #9
ScottPM's Avatar
ya saw that. my national had power tilt on the rear camera so you could move in while backing up. was a nice feature . But I am really liking the Legacy so far
Scott Menard
2015 Legacy 360 RB
Old 04-12-2016, 12:11 PM   #10
We love ours....6000 miles on it from July 18th till November when we put her away...and I still work full time so I do not get away as much as I like...I have a FBook for the Legacy also which we share lots of travel photos
