Old 10-06-2017, 04:01 PM   #1
DrJAG's Avatar
Recaulk Front and Rear Cap Seams
Just washed the roof and noticed the caulking on the front and rear cap seams is starting to dry out and crack. Anyone replaced theirs? Thoughts on using Dicor sealant vs Eterabond tape... Thanks
-DrJAG
2015 Legacy 360RB with 2013 CRV toad. Retired USAF.
DrJAG is online now   Reply With Quote
Old 10-06-2017, 07:00 PM   #2
cardwellmarty's Avatar
I did both, I removed the old sealant and put Self leveling dicor sealant, l let it set a couple of days and put 6 inch Eternabond, some will say why you are putting Eternabond over it, but it's the way I did, no second guessing if it's sealed. I also did all my cleaning for the Eternabond when I was cleaning up for dicor, I use Acetone and have had no problems, my roof is a TPO roof.
cardwellmarty is offline   Reply With Quote
Old 10-06-2017, 07:24 PM   #3
I peeled off the old caulk, wiped with acetone, and put Eternabond over the seam.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 10-06-2017, 07:49 PM   #4
Just as confused as you
Scrapper's Avatar
Eternabond has 10 year life, dicor has 2 to 5 years.
Richard & Jill
Camping since 1989, seasonal since 2000
Old 10-06-2017, 07:59 PM   #5
Kind of curious - what happens to the dicor 5 years after being covered by the 10 year Eternabond? I would imagine the eternabond extends the life of the dicor but to 10 years? (I have neither the expertise nor the experience to know for sure).
2012 Sunseeker 2250S/2008 Yamaha Venture (1300 cc V-Four)
rebellee is offline   Reply With Quote
Old 10-06-2017, 08:15 PM   #6
I didn't add that i use Eternaprime in my earlier post before the Eternabond.
Old 10-06-2017, 08:33 PM   #7
Scrapper's Avatar
I really couldn't tell you the answer. I do know some on the forums, me included, have put Eternabond on the seams before problems started. While doing mine I noticed that FR put Eternabond on the slides where the roof meets the outer wall flange.
Richard & Jill
Old 10-06-2017, 09:15 PM   #8
Canadian Member
The caulk will dry out and start to crack. That’s normal and a normal maintenance item to touch it up. Eternabond is a much more long term solution. No need to remove the existing caulk before applying the Eternabond. When I did my last trailer, I touched up the Dicor and allowed it to cure for a week before applying Eternabond over it. I used the 6” wide tape on that joint.
2019 Rockwood Signature 8290BS
Old 10-07-2017, 01:17 PM   #9
Having learned my lesson on or first MH, I taped all the roof seams on or new PrimeTime the day after we bought it
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
kayo is offline   Reply With Quote
Old 10-08-2017, 04:41 PM   #10
Filterman's Avatar
Had a good look over our roof this year and added a little Dicor to some spots that looked iffy. Thinking of doing the end cap joints in the spring and Eternabobd sounds like a good solution for the roof Sean's. what is everyone using to refresh the vertical seams on the end caps where they meet the sidewalk of the trailer?
Filterman is offline   Reply With Quote
caulk
