Old 02-03-2018, 12:29 PM   #1
psw757's Avatar
Replacement house batteries
Looks like I will likely need new house batteries for our 2014 this spring. Just not holding charge with this cold weather even though all battery disconnects are off. And I do turn them on when I exercise the generator so they get a charge.
Anyone replace theirs yet and what do you all recommend?
psw757 is offline   Reply With Quote
Old 02-03-2018, 12:52 PM   #2
The largest (Amp Hour Capacity) battery that will fit the space available.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 02-03-2018, 07:00 PM   #3
Lacey's Spring, AL
formerFR's Avatar
it looks by your picture that you might have a Berkshire.... I wouldn't think you'd already need to worry about replacing your house batteries - if you have the Magnum Inverter/Charger and it's LCD panel, you can push the CHARGER button for several seconds, if memory serves correct, and it will take your batteries into EQUALIZING mode, as long as you are plugged into 50a service.
This is a way to 'balance' your batteries, by the system carefully 'overcharging' them for a set period, usually about 3 hours or so. This brings each battery level with the other, and often times will 'refresh' your battery's outputs, like new!
but, look at your Magnum manual, or this website link, to be sure:
https://www.manualslib.com/manual/53...c.html?page=32
enjoy your Berkshire!
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx,
100,000+mi since '14, US, Alaska, Canada, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 02-04-2018, 08:41 AM   #4
psw757's Avatar
I will give this a try before I buy batteries.
batteries, replacement
