Old 04-20-2018, 01:46 PM   #1
Residential Refer- Does electric auto switch?
I have been looking around the forums and canít seem to happen up on an answer so here I am with a mouthful of Gimme and a hand full of Thank ye kindly.
Does the electrical supply switch automatically to the inverter when you are off gen and off shore power or is there a switch of some sort that I have missed?
Yes, I am a NOOB - 1st motorhome
2018 Forest River Legacy.
DTordoff is offline   Reply With Quote
Old 04-20-2018, 01:58 PM   #2
TKN 516's Avatar
As far as Iíve been able to tell, you have to push the inverter button on the magnum power panel on the left. Some people leave the inverter on all the time, but my last coach had weak house batteries so I didnít use the inverter as much.
When we roll we almost always start the generator and donít turn it off much until we plug in somewhere.
Iíll play with mine and see how it behaves...
Tim & Nicole
2018 Legacy 38C
2015 Jeep Rubicon TOAD
TKN 516 is offline   Reply With Quote
Old 04-20-2018, 07:00 PM   #3
typically a residential refrigerator will come with an inverter. there may be a small transfer switch (not a generator transfer switch) to switch power from shore (or generator) power to inverter power when shore or generator power is not present. some inverters actually have this transfer switch built into them internally. however, the inverter must be on for this to happen. there is normally a remote switch that can be used to power the inverter on or off. there is much discussion and personal preferences about whether to leave the inverter on all the time (other than in storage) or to turn it off when on shore power.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
Old 04-21-2018, 07:47 AM   #4
srappleby's Avatar
The inverter on/off will be controlled by the Magnum control panel. You should find this on a wall, about eye level in the middle of the coach. There is a button on the left hand side - push to turn it on, push to turn it off. Turn this on when you need 120v ac power in your coach. It will supply power to everything that would get ac power off the generator or shore power. But, find out how many watts your inverter is and only use appliances that are within that range. For instance, the air conditioner units will be too high to use power from the inverter and it will trip something and show "Fault" on the control panel.
In my 2014 Legacy, with the inverter on, I run my fridge, all ac outlets, and tv's. If we need a/c, microwave, or coffee, gotta run the generator.
In my experience, once you turn the inverter on, it stays on. So, run the generator for what you need then, when you turn it off, the inverter goes back to supplying power.
Just to be sure you know what's happening here, the inverter takes the 12v dc power from your house batteries and kicks it up to 120v ac. How long the batteries last with the inverter depends on how much you are using. While this is happening, the batteries are still supplying 12v power to all the 12v things like lights, alarms, etc.
We have found that while running down the road, we can use the inverter to keep the fridge running and power tv and ad outlets without running the generator. This is because the house batteries are being charged while the Diesel engine is running. Only use the gen set when we need to heat something in the microwave or get dinner started in the croc pot.
2014 Legacy SR300 340BH
2010 CR-V Toad
srappleby is offline   Reply With Quote
Old 04-21-2018, 08:16 AM   #5
TKN 516's Avatar
Hey srappleby,
I agree with everything you said, but wanted to ask a follow-up question on charging while driving. I havenít seen a wiring diagram nor have I closely watched the watched the battery voltage on the house batteries while driving. I do know though that on the Ď14 Legacy we had, the House batteries wouldnít hold too long. So that is why we frequently ran the generator.
I was always under the impression that in order to bond the house/coach batteries, you have to have the Aux Start switch up front held/pushed in, in order for the alternator to charge house batteries.
Also, I donít think that there are diodes in the circuit because one time when my batteries were weak, I had to hold the Aux Start switch to get the generator started and keep it running until the voltage came up. So it works both ways (house to coach batteries and vice versa)
I had a dealer tech recommend to me one time to start the generator and slip something behind the switch the to hold the circuit closed. Which makes me think that he too was operating under the premise that coach/house batteries are not bonded...
Iíll have my wife watch the voltage from the Precision Plex app when we roll next time so Iíll know for sure.
Tim & Nicole
2018 Legacy 38C
Old 04-21-2018, 08:43 AM   #6
srappleby's Avatar
There is a schematic on the compartment door where my inverter/charger is mounted. But, unless you're an electrical engineer, good luck with that one. Lol.
Along the way, I have had a few techs who said that both sets of batteries, chassis and house, will be charged my the alternator on the engine, by the generator, or by shore power.
A couple of things I've done that supports this theory -
the last couple of times we were on the road, I ran only off of the inverter and the house batteries were topped off when the trip was done.
Once, while stored for a couple of weeks, the house batteries were too weak to start the generator. Instead of using the Aux Start crossover switch like usually do, I instead turned on the engine and ran that for about 15 min at idle. Batteries had enough juice to fire the generator.
The real test would be to compare voltage of the batteries before starting the coach and then after it is running. I just can't ever seem to remember to do this but, some day!
As far as having to hold the Aux Start switch to keep the generator running.....just a theory here but, I'm thinking the house batteries were so low that there wasn't enough to keep the generator running until the generator starting charging the batteries. Important info to keep in mind for anyone who doesn't know is that when you start the generator, there is about a 2 min. delay before it supplies juice to anything. This is to allow the generator to warm up with no load. So, you may have needed to hold that switch so that the chassis batteries could supply 12volts to the generator engine until the generator itself starting putting power into the charger and charging the batteries. Again, just a thought
Another situation I just remembered- once after taking a vacation without the rv (I know, right?) house batteries were low so I attempted to start the coach. The chassis batteries were also too low so I freaked out for a few moments. Then, I rationalized that the generator probably needs less amps to stat so, I held the Aux Start switch, started the generator, then ran that for about 15 or 20 minutes until the chassis batteries were charged enough to start the big engine. I probably could have used the cross over switch again but I didn't want to risk shutting down the generator.
2010 CR-V Toad
Old 04-21-2018, 10:06 AM   #7
TKN 516's Avatar
Agree. I only ever had the one issue, so I havenít spent much time on it... weíre out at a campground in eastern NC this weekend. Iíll look at the gauges on the way home.
Back to DTordoffís question; did you get the information you needed?
Tim & Nicole
2018 Legacy 38C
Old 04-21-2018, 01:24 PM   #8
Retired Member
rmwmiata's Avatar
Don't have generator but tech told me to turn off inverter when on shore power.
Pam and Murry Wilbanks
2018 SIERRA 377 FLIK
2018 Ram Laramie 3500 DRW
rmwmiata is offline   Reply With Quote
Old 04-21-2018, 06:15 PM   #9
camaraderie's Avatar
Does your fridge compressor come on when you are plugged in and the inverter is off? If so...the tech is right.
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 04-21-2018, 07:27 PM   #10
Retired Member
rmwmiata's Avatar
Yes it does. Had first trip last weekend in new rig with residential fridge. Still learning.
electric, switch
