Old 05-13-2018, 10:41 AM   #1
jvenditte's Avatar
Running the water pump while on city water
I ran the water pump while on city water for 24 hours. Can that cause electrical issues? I have a brownout condition on line 2.
jvenditte is offline   Reply With Quote
Old 05-13-2018, 10:46 AM   #2
fonzie's Avatar
It should not as the pump is 12 volts dc
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-13-2018, 10:55 AM   #3
I would be surprised if the pump actually ran.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 05-13-2018, 10:57 AM   #4
jvenditte's Avatar
Old 05-13-2018, 12:45 PM   #5
It should have detected the pressure in the line and turned itself off correct?
The Lieutenant is offline   Reply With Quote
Old 05-13-2018, 01:07 PM   #6
Dahagen
When I am at a campground with low water pressure I will run the 12 volt pump also to increase water flow for a shower and draw extra water from the fresh water tank.
dahagen is offline   Reply With Quote
Old 05-13-2018, 01:07 PM   #7
If your connected to city water the pressure in your hose would not have let the pump even turn on
Kygoldwinger07 is offline   Reply With Quote
Old 05-13-2018, 01:35 PM   #8
Brown out most likely in the park line supply breaker, one of the two tied together at the pedestal. Try resetting it first.
BreadBox is offline   Reply With Quote
Old 05-13-2018, 02:27 PM   #9
Just as confused as you
Scrapper's Avatar
You don't need to use your water pump when connected to city water. That should have been covered in your PDI unless you bought from a previous owner and they neglected to mention it. Many times using the two together can cause problems by jamming the check valve at the pump thus filling the fresh water tank.
It has nothing to do with brownout conditions. Check your pedestal breaker by turning it off then back on. If that doesn't fix it then check the main breaker inside your RV by following the same procedure.
I have never used my water pump except for winterizing.
Richard & Jill
Camping since 1989, seasonal since 2000
Scrapper is online now   Reply With Quote
city water, pump, water, water pump
