Old 04-07-2016, 12:24 AM   #1
Rust!
Have any of you noticed a lot of rust underneath the coach, especially on the metal floor supports? Is this normal? I was told it had been undercoated? I'm confused.
Has anyone found a suitable product which I could apply to prevent this.
I also had a lot of corrosion in both battery compartments.
necasperaterrent is offline   Reply With Quote
Old 04-07-2016, 12:49 AM   #2
Corrosion X is an incredible product and can be sprayed on most materials. I use it to undercoat vehicles that see salt and I also use it on the interior unprotected surfaces of metal airplanes.
Some people use ACF-50 but I have no experience with it.
KatanaPilot is offline   Reply With Quote
Old 04-13-2016, 09:21 AM   #3
aeroshots's Avatar
I've used this for years with good results. Place a small amount in a generic household hand pump sprayer, i.e. cleaner bottle. Mist it on the rusted metal. Allow to dry 24 hours then coat with paint or other coating of your choice.
I believe its active ingredient is Phosphoric acid.
Phosphoric acid (also known as orthophosphoric acid or phosphoric(V) acid) is a mineral acid having the chemical formula H3PO4. Orthophosphoric acid refers to phosphoric acid, which is the IUPAC name for this compound.
..2016 Legacy 340KP SR340, 10,500 Miles..
aeroshots is offline   Reply With Quote
