Old 07-23-2019, 08:11 PM   #1
Safe-T-Alert power issue
This carbon monoxide / propane gas detector aged out and I removed it and purchased a new one. A 2 minute job just connecting two wires but it did not work. Testing the voltage on the wires and I only get slight current (.01 to .02) where it should be 12 volts. Does anyone know where these wires come from? I donít see a fuse for it but would think it would be directly wired to the batteries some where and not a fuse. Thanks for any help.
skip33 is offline   Reply With Quote
Old 08-01-2019, 07:14 PM   #2
CO/LP Detector Power Source
Depending on your model & year, the CO detector is powered by a either a 5A Circuit Breaker in the compartment to the rear of the battery compartment (with the Hydraulic Pump) or a 5Amp ATC fuse in a fuse holder attached to the House battery positive.
red0801 is offline   Reply With Quote
Old 08-19-2019, 10:31 PM   #3
Thank you !! Itís a 2015 Legacy KP. I tested the 2 fuses that were attached to wires laying in the battery compartment and they were good. The Hydraulics are on the other side so Iíll look there tomorrow. Where can I get some schematics to look at ??
Old Yesterday, 08:25 AM   #4
red0801,
Thanks as it was the fuse in the inverter bay !!!!
Old Yesterday, 10:03 AM   #5
You are very welcome.
power
« Door Latch failure | - »
