Old 01-05-2018, 08:08 AM   #1
Seat belt recall.
I received a recall on my 340BH about the shoulder seat belt being to low. Has anyone had this work done? The recall says it will take 3.5 hours to repair. If you had this change made did it leave holes or damage were it was? Are you pleased with the change or was it worth the trouble? Thank you. Not sure.
Just starting is offline   Reply With Quote
Old 01-05-2018, 10:12 PM   #2
CRL1's Avatar
Some time ago I posted the instructions for doing this recall. Unfortunately I don’t remember where.
CRL1 is offline   Reply With Quote
Old 01-05-2018, 10:15 PM   #3
I seen it. Thank you. More to it than I thought too. I talked to the dealer today. He was unaware.
Old 01-05-2018, 11:22 PM   #4
I had the recall done, no extra holes exposed. They used a plastic trim plate. Dealer said the challenge was fishing the nuts up inside the wall from under the coach. The belts do fit better and not fall off the shoulder when driving.
tmartin is offline   Reply With Quote
Old 01-05-2018, 11:34 PM   #5
Thank you Sir.
recall
