Old 08-11-2018, 04:10 PM   #1
jvenditte's Avatar
Slideout failure 2018 legacy 34a
Returning from a camping trip we stopped at a KOA a few hours from home. The wardrobe slide went about halfway, then stopped. Tried to manually reset the slide box in the compartment under the wardrope tried to reset power with the house connect button by the entry door. Tried running the coach on idle for about ten minutes then I will need to pull the 6 pin connectors on motor one and motor two push the slide in manually and get it to a repair shop.
The coach is six months old....
Anyone one else experience a slide out failure?
jvenditte is offline   Reply With Quote
Old 08-13-2018, 08:40 PM   #2
jvenditte's Avatar
Unplugged the two 6 pin connectors on the controller and was able to manually push the slide in. When we left, the slide motor came on when I hit the close slide switch. Motor did not come on when it was stuck.
Old 08-16-2018, 04:08 PM   #3
DieselDude916's Avatar
Keep us posted as to what the dealer says
DieselDude916 is offline   Reply With Quote
Old 08-16-2018, 04:49 PM   #4
jvenditte's Avatar
slideout
sure thing. Forrest river indicated it "sounded" like a loose wire. I am going in a few weeks to a service shop to have it checked out.
Old 09-18-2018, 01:05 PM   #5
jvenditte's Avatar
My slide out issue was an intermittent issue. They could not duplicate the failure and it seems to work fine now. I did not have any alignment issue when I manually pushed it in to drive home. all is good.
slide
