Old 10-24-2014, 12:00 AM   #1
43D18's Avatar
Slit in bottom of LR slide open to elements?
Hey gang,
So I posted this in the "Legacy evaluation so far" thread but also posting here to perhaps be visible to more folks -
So - we looked a bunch of Legacy coaches today and I'm curious about something. At one point my DW, when looking at the area underneath the sink, said "wow you can see a lot of daylight under there". It looked to be a slit in the bottom of the slide w/ two rubber flaps - but there was still a lot of open space to the outside. With all the plumbing under there, I would think that area would be extremely susceptible to freezing in cold temps with that open slit exposed.
Anyone else notice this? Surely there must be a way to make that more weather tight - besides open access for vermin, that area under the sink would get *extremely* cold.
Remedies? Thoughts?
Thanks much,
-Mike
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Buck & Patsy, the boston-mix guard dogs
43D18 is offline   Reply With Quote
Old 10-26-2014, 11:56 AM   #2
43D18's Avatar
Comments...anyone?
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Old 10-26-2014, 04:37 PM   #3
psw757's Avatar
The purpose of the slit is the slide moves a rounds quite a bit of plumbing and electrical lines coming up through floor inside of first cabinet under sink.
I haven't had any issues with it, i also haven't come up with a reasonable fix for it either. It seems that with furnace on the basement compartments are kept warm. I'm not sure freezing is an issue if your using heat but the varmint and insect issue was more of our concern.
I would like to seal it up but not sure how it can be done given the slide moves around all those hoses and wires in the front corner of that cabinet.
Overall very happy with the coach. Yes there are little things that make you scratch your head but for the most part very well built.
psw757 is offline   Reply With Quote
Old 10-29-2014, 11:39 AM   #4
lrob's Avatar
Thanks for the info. I am still waiting to hear from my factory rep on a remedy. When I do, I will post it here .
2014 Legacy SR300, 340BH
Toad: 2011 GMC Acadia
" On the go to see something amazing"
- Psalm 107:23-24
lrob is offline   Reply With Quote
Old 10-31-2014, 03:00 PM   #5
lrob's Avatar
Heard from the factory about the slit. Here is what he had to say:
" the “slit” under the slide out that you sent me a picture of…there really is no way to seal it up 100%. It needs to be left somewhat open since there are parts that need room to move when the slide out or moved in or out. You might be able to find something that will help, but you need to make sure it is thin enough that it won’t obstruct the movement of the slide room"
Translation to me: duct tape
I'm gonna use some to block the opening and work with it to ensure I can seal it somewhat
- Psalm 107:23-24
Old 11-05-2014, 10:53 PM   #6
43D18's Avatar
Have say sadly this could be a deal breaker for me. As we do a fair amount of travel in cold weather months, I can't see the area under the sink being that exposed to the cold. I can't fathom that an engineer thought that was a good idea.
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Old 11-06-2014, 10:17 AM   #7
lrob's Avatar
I hear you. I'm going epoxy some Velcro on to the flaps and when I open it, i can seal it.
- Psalm 107:23-24
Old 11-08-2014, 06:54 PM   #8
43D18's Avatar
Hi lrob. Any chance that's your coach in the 700 loop at Fort Wilderness? If so, we are in same loop.
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Old 11-08-2014, 07:17 PM   #9
lrob's Avatar
No. I'm up in MA. I wish I was there. In a couple of years.
- Psalm 107:23-24
Old 11-10-2014, 07:59 PM   #10
lrob's Avatar
After talking again to the factory rep again, apparently all models are done with the slit. You might want to check. At least that is what he informed me of so it appears that the Legacy is not the only model.
- Psalm 107:23-24
slide
