Old 06-03-2016, 08:02 PM   #1
US MARINE
MarineOne's Avatar
Total solar legacy
Brian Boone is a solar expert who is traveling across the country and installing solar systems as he goes. We have been wanting to go total solar with our legacy and Brain made that possible.
We contacted Brian via FaceBook and arranged for him to stop by and hook us up. He gave us a list of what we needed and we ordered it and had it waiting when he arrived. Right in our driveway, he took two days and worked his buns off to give us a Class, A, Top Notch, solar install.
Now we have 8, 160 watt solar panels (over 1200 watts), two blue sky controllers and never need to use shore power again. It was a blast watching our system easily providing more power than we were using.
We liked it so much I have ordered 4 more 160 watt panels and another controller. This will give us almost 2000 watts of solar power. Brian will be back to install them in a couple of months. With that much solar we will be able to operate one of our ACs on pure solar power, as well as all of our normal lights, TVs,........and all without touching the batteries during the day. The Legacy roof is perfect for the solar install and provides more then enough space to give you all the power you need.
MarineOne is offline   Reply With Quote
Old 06-03-2016, 08:09 PM   #2
US MARINE
MarineOne's Avatar
Pics Added
ID:	110065   Click image for larger version
ID:	110066   Click image for larger version
ID:	110067   Click image for larger version
ID:	110068   Click image for larger version
Old 06-03-2016, 08:30 PM   #3
SeaDog's Avatar
be careful what you drive under. That is the most solar panels I have seen on a rig you sure will be off the grid
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-04-2016, 05:47 PM   #4
aeroshots's Avatar
PM sent to marineone
..2016 Legacy 340KP SR340, 10,500 Miles..
aeroshots is offline   Reply With Quote
Old 06-05-2016, 01:02 AM   #5
dmwoody's Avatar
List of goods, suppliers, cost of goods, cost of install ??
When does he get to the left coast.
Dan
dmwoody is offline   Reply With Quote
Old 06-05-2016, 03:51 AM   #6
US MARINE
MarineOne's Avatar
Here is Brian's Blog address. He did a god job listing all of the supplies and what he did. As far as his schedule...contact him via FB and ask. I know that now he is headed East to Nashville and then turns north for the summer, back to my place in West TN. to put on 4 more panels in September, then he and his wife are spending three months in Middle TN. I think he said he was headed back West starting in January.
He's well worth waiting on if you can. When he did my install he charged $75 an hour. Mine was a bit more complicated than some (he had to work in some pretty small spaces) and the weather was very hot and humid. He doesn't take a lot of breaks and works pretty fast. It took him about 11 hours of work to complete mine. He will need another 6 or so hours to put on the other 4 panels when he returns. That is mostly my fault. I didn't decide I wanted the extra 4 panels until after he had already run and installed the main wires so he has to do it again.
Total cost on my project, when he has all 12 panels up, will be about $7000. I have a bit more on my roof than most do or most need so don't let that shock you. That number also includes his labor. The list of materials are on his blog but I started out with 6 FULLRIVER AGM batteries and a Magnum 2000 inverter.
I have a modified sige inverter that came with the coach and it seems to be doing fine but keeping my eye on a pure sine 2800 just incase.
Ill go ahead and list what he has on his blog......
Finished my Solar install in Collierville,Tennessee today. We have (8) 160 watt Solar panels and (2) Blue Sky MPPT Solar Boost 30/24i Controllers. 4 panels to each controller. For a Combined total of 80 Amps / 1280 watts.
This is a 12 volt system. Each Panel is wired separately on #8 wire to a Combiner Box . There I switch to #4 wire going to controller, then batteries.
Wire from controller to batteries has a 50 Amp resettable circuit breaker. Controllers are stacked together ( can stack 7 ).
All controllers run through the Pro Remote. 2 controllers MAIN / SLAVE 1. Main holds Temp Sensor, 2 Amp charge for Starting Batteries, Remote Panel. Installed on a 37 ft. Motorhome.
We are heading to our next job Sunday in Columbia, Tennessee.
He is big on getting the controllers and the remote from AM solar.
Old 06-05-2016, 04:49 AM   #7
nomad297's Avatar
Wow! You'll never have to wash your roof again!
Bruce
Old 06-05-2016, 08:09 AM   #8
US MARINE
MarineOne's Avatar
Bruce
LOL. Part of the master plan.
Old 06-05-2016, 11:17 AM   #9
fr1rd831's Avatar
What is the AH rating of your batteries?
Ray and Maria
Lincoln CA
Our Forest River Gallery & Family Photo's link
fr1rd831 is offline   Reply With Quote
Old 06-05-2016, 11:46 AM   #10
US MARINE
MarineOne's Avatar
224
solar
