Old 06-09-2015, 02:09 PM   #11
DrJAG's Avatar
Had another heavy rain last night. I checked the two compartments and found no water in one and a few large drops in the other (could have gotten wet when I opened the door). So hopefully my adjustment to get the door to seal a bit tighter worked. Will see how it does in next rain. Still need to check compartments on driver side when slide is in and all compartments when driving in rain.
-DrJAG
2015 Legacy 360RB with 2013 CRV toad. Retired USAF.
DrJAG is online now   Reply With Quote
Old 06-10-2015, 06:31 AM   #12
psw757's Avatar
Did you crawl underneath to see if you can see any carpet fabric sticking out from the angle iron framing for the compartments?
psw757 is offline   Reply With Quote
Old 06-10-2015, 07:06 AM   #13
DrJAG's Avatar
Psw757, these two compartments do not have carpet. I will look at the others to see if that could be an issue, especially when driving in the rain. Thanks.
-DrJAG
Old 06-10-2015, 07:21 AM   #14
WestCoastRV'er's Avatar
landing gear switch leakage
Found quite a bit of water in the front curbside storage compartment of my 360 RB after a recent heavy rain. Anyone else have this occur?
I had this happen this spring and found my issue. The electric switch for the landing gear has foam to seal out water, which had failed. When I looked from the inside at the switch I could see daylight. Resealed the switch with dicor. I also checked the rear switch and found it had been leaking too.
After my repair, I ran water from a garden hose to verify the door and switch were not allowing anymore water to get into the front storage compartment.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 06-11-2015, 05:40 AM   #15
WSY DD693's Avatar
I bought a 2008 Surveyor and had water in the cargo hold that seeped into front bedroom carpeting. The fix was replacing worn out door seals, but I agree with others moving water away from the TT sides via longer rain spots, purchased or Gerry Rigged clothes pins. whatever works for your budget.
2008 Modified Surveyor 303
2010 Dodge Ram Laramie 4x4
2013 From FL to Pick up Surveyor Islip,LI, PA,NY,VT,NH,MA,CT,NY and Home
2014 Sebastian Charleston,SC to Finger Lakes, Lake Erie, Lake Cowanesque,PA and home
2015 Sebastian to PA,NY,WI,MN,return to NY and home
2016 GA,SC,NC,TN,KY,OH,PA,NY,to Sebastian,FL
WSY DD693 is offline   Reply With Quote
Old 07-01-2015, 08:17 AM   #16
DrJAG's Avatar
Had another hard rain yesterday. No water got in the storage compartments. Noticed that water is channeled along the seam where the roof meets the front cap down along the side windows, leaving dirt streaks. Guess the water has to go somewhere but wish is didn't mess up windows.
-DrJAG
Old 07-01-2015, 08:26 AM   #17
7 Year Class A RV'er
Our 360RB stays parked in the driveway. We had 8.95" of mostly hard blown rain in June and no water in the compartments. My old RV, parked in the same spot, used to have water in three of the compartments continuously. All I would know to do is check the door seals.
2015 Legacy SR340 360RB
Old 07-01-2015, 08:48 AM   #18
leak
make sure camper is level,also check your lock latch, you need to use all 3 for the best seal the 2 plus the key i have a 2860 and my front had a small amount in it but not sure how.Might of been from storm or when i washed it.
retired on a mountain is offline   Reply With Quote
Old 07-01-2015, 09:00 AM   #19
clr
I had a problem with water getting into my front storage compartment also. I found that the seal below one of the latch strikers was rolled slightly so this was allowing water to run under the seal and directly into the compartment via the sidewall. I removed the latch strikers and used liquid electrical tape, but dicor or any silicone type calk would work to seal the void under the strikers. I also removed the screws and dabbed each one and then replaced. Have now been through several hard rain storms and no water in the compartment. Hope this may help everyone.
clr is offline   Reply With Quote
Old 07-30-2015, 08:25 PM   #20
W4JJ's Avatar
I have a 2014 Legacy 340 BH. My unit has been to the factory twice and a third visit by a team of experts to repair my leaking storage compartments. After having new rubber gaskets and locks installed, and they still leak from rain while driving down the road. I have come to accept this as the FR standard for this unit after a year of ownership.
Jack
2014 Legacy 340BH
Arlington, VA
W4JJ is offline   Reply With Quote
storage, water
