My coach is the 2018 Legacy model 34A. It indicated it was pre wired for Satellite and solar. The We Boost Drive 4G-X RV | 47041 shows in the installation instructions that you should drill a hole on the side of the RV to route the antenna cable inside to the motorhome to connect to the signal booster. Is there an existing hole on the roof of this RV to route the cable without drilling a hole?
There are only 2 markings on the roof, one for the SAT installation using pre-wired cables and one for the solar power cables
No markings in the roof to drill anything else, I would drill where they say to do so, I assume on the right side just behind the TV.
