Old 12-14-2015, 10:43 AM   #1
ScottPM's Avatar
winter storage
Hey, just a quick question, does anyone level their coaches during the winter and just leave the jacks down? if you do,do you coat the pistons with anything?
Scott Menard
2015 Legacy 360 RB
ScottPM is offline   Reply With Quote
Old 12-14-2015, 02:33 PM   #2
Blacknchromehd's Avatar
Well mine is inside in the warm so no it does not have the jacks down.
Blacknchromehd is offline   Reply With Quote
Old 12-14-2015, 02:41 PM   #3
ScottPM's Avatar
lol thanks!! working on that arrangement for next winter
Scott Menard
2015 Legacy 360 RB
Old 12-14-2015, 03:00 PM   #4
aeroshots's Avatar
Mine is inside also, but has the jacks down. Is there a preferred method for jack during idle times? I just figured jacks down to relieve the weight from the bags and rest of the suspension components.
..2016 Legacy 340KP SR340, 10,500 Miles..
aeroshots is offline   Reply With Quote
Old 12-14-2015, 03:10 PM   #5
ScottPM's Avatar
Guess my only concern would be the effects on the jacks sitting extended for 4 months during the winter.
Scott Menard
2015 Legacy 360 RB
Old 12-16-2015, 01:31 PM   #6
captnrick3's Avatar
If you do that, when it comes time to retract the jacks, I would wipe the shafts good and coat with a good silicone lube before retracting. If it were me, I think I would put plywood or thick plastic under the tires, deflate the airbags, leave the jacks retracted and call it good.
Fortunately our rig is parked under cover in the back yard and we use it year round.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 12-19-2015, 09:43 AM   #7
7 Year Class A RV'er
We're in Florida, so no cold weather, but we do keep it jacks down and leveled in the driveway, hooked up and AC running, I was told not to use WD40 or silicone spray on the jacks as those would collect dirt, but there is a Teflon spray they sell at Lowe's that works really well and dirt doesn't stick to it. Same thing they use on bicycle chains to keep the lubed and clean. Directional long range spray nozzle, too.
2015 Legacy SR340 360RB
Old 12-19-2015, 10:07 AM   #8
Where mine is stored for the winter, it's not covered so the front jacks are extended and the front raised just past level so rain/melting snow can run off the back of the 5er. The tires sit on 8x10x 4ft pieces of wood and the tires covered. Goes into storage in October and comes out in May, usually.
Pipeman is offline   Reply With Quote
Old 12-19-2015, 10:43 AM   #9
No real need to level your Motorhome, you wont be using fridge while in storage and if it is off level the water will run off the roof , so I don't see a need to put jack down.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 12-19-2015, 10:47 AM   #10
jeff64's Avatar
Mine sits on 2.x12s, on blacktop, somewhat level with the stabilizers up. Dealer serv mgr said don't cover it, leave roof vents open since the maxair covers are on it
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
storage, winter
