Old 06-01-2015, 08:08 AM   #1
Another possible leak area on the 1961 Airflyte Reissue
Check the marker light areas for proper fit. They drilled an inch and a half hole to run two wires out of and if the light is not centered over it properly, you could definitely have a leak issue. On mine it's clear the light was attached incorrectly and exposed part of the hole behind it. They make a botched effort to fix it with silicone, so I removed it and decentered the light to cover the hole.
ID:	78688   Click image for larger version
ID:	78689   Click image for larger version
ID:	78690   Click image for larger version
pcmichelle is offline   Reply With Quote
Old 06-01-2015, 08:21 AM   #2
vinmaker's Avatar
Wow. Seems a bit overkill to drill a 1.5" hole for two thin wires.
Good catch on your part and fixing it before you have trouble.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 06-01-2015, 08:57 AM   #3
wmtire's Avatar
Vin.
X2. Many thanks pcmichelle for posting the pics and the solution. This will help members in the future who have the same problem.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 06-01-2015, 09:18 AM   #4
KyDan's Avatar
1 1/2" hole behind a marker light is CRAZY!!! Where is QC oversite??
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 06-01-2015, 11:20 AM   #5
Wow. That's crazy.
Red Airflyte 16'
smittydc is offline   Reply With Quote
Old 06-04-2015, 07:23 PM   #6
Another example of "Shasta measuring."
DouglasLive is offline   Reply With Quote
leak
