Old 08-18-2018, 06:52 PM   #11
From what I can tell online your RV has wood studs with wood paneling construction. If that is the case it COULD be possible to remove a wall panel and hide the wire in the wall. If it has glass insulation that would make it even easier. If you attempt that make sure you secure the wire to the stud with plastic or rubber protected wire staples/nails. Use the plastic or rubber to help avoid chaffing of the Romex wire cover. I am not an electrician but that is the direction I would attempt at first if it were mine.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 08-18-2018, 07:59 PM   #12
Originally Posted by Oaklevel View Post
Welcome to the forums !!!!!!
I would let them use the wire mold and run the wire on the wall it is not a big deal it is done in houses and buildings all the time. It is a camper.......
You're right... its just a camper, i'm just trying to be too fancy i think.
I appreciate the input.
Thanks.
marrmalian is offline   Reply With Quote
