Old 05-22-2015, 10:53 PM   #1
Where to locate your build number?
I have no idea what 1961 re-issue number i have. Where can i look? Thx
regalrow is offline   Reply With Quote
Old 05-22-2015, 11:24 PM   #2
wmtire's Avatar
Your VIN number on your paperwork, the frame, or possibly in an inside cabinet should tell this. The tenth and eleventh digits are your year and assembly plant codes. After that is when you run into your series numbers. I am assuming that Shasta is coding them in sequential numbers as they build them. However, I have seen two styles, so they may not have the numbering like between 1 and 1941. Let us know what you read on yours.
It should be like in the pic below:
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 05-23-2015, 12:46 AM   #3
TURBS's Avatar
Last 5 of your vin
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "6 nights"
Old 05-23-2015, 09:46 AM   #4
Build number
My last 6 are 610586, so is this number 586 out of 1961? And does anyone know if this is first or second build?
Redbetty is offline   Reply With Quote
Old 05-23-2015, 10:05 AM   #5
wmtire's Avatar
Wouldn't that be 586 out of 1941. I have read where the number of production models is going to be the beginning year of Shasta as a company... 1941.
1961 Shasta Airflyte Reissue
Maybe someone more in the know, can answer your question about the production run. I think usually the 12th or 13th digit of the VIN is a code for that.
It's possible that the 1 is your production run and you have the 586th one of these. But this is a guess somewhat.
Old 05-23-2015, 09:18 PM   #6
586 is probably from the Fall 2014 (first) run. Ours is #407, delivered to the dealer in November.
DouglasLive is offline   Reply With Quote
Old 05-23-2015, 10:08 PM   #7
wmtire's Avatar
I found this in an older owners manual.
Name:	FireShot Screen Capture #094 - 'manual_pdf' - www_rvzen_com_lp_mmy_forest-river-rockwood-roo-23s.jpg
Old 05-23-2015, 10:14 PM   #8
wmtire's Avatar
and this from 1999 indicating many of the codes used by Forest River lines at that time frame:
ftp://safercar.gov/MfrMail/01-22-N11B-7432.pdf
cat
