Old 06-09-2019, 11:53 AM   #1
1st time towing our new Grey wolf alone
hey hey! HELP-im a newbie. I am buying my mothers 2018 Cherokee Grey Wolf 29te. Its 36.5 in length. We bought a 5.7 Toyota Tundra for pulling. Heres my question....The rv is in the Keys and I am druvung from Austin, TX to pick it up...ALONE. I will be driving it back 1600 miles with me myself and i. I am a confident driver and have driven big uhauls and stuff across the country but im sure i could use some solid advice. I got this right? Any advice, tips majorly appreciated.
Carmenroams is offline   Reply With Quote
Old 06-09-2019, 11:58 AM   #2
BigH's Avatar
Good luck and drive slow...that is a bunch of trailer for that truck.
17 Chevy 2500 DC Long box Gasser Z71 4.10
18 Vengeance 28V
BigH is offline   Reply With Quote
Old 06-09-2019, 12:08 PM   #3
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. I assume you have a WDH with sway control if not get one. Keep the speed below 65 and if it gets windy (like it does in that country) pull in somewhere and camp. check the tire pressure before you start out each day fill to the max sidewall pressure. Good luck
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-09-2019, 12:30 PM   #4
X2 on needing a more heavy duty truck. Also WDH would be a must for me.
TV - 2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Drinks of choice: woodford reserve, knob creek & any great bourbon-just about any of San Diego’s craft beer and Pabst Blue Ribbon
Beachbourbon is offline   Reply With Quote
Old 06-09-2019, 01:03 PM   #5
Grammar Pedant
67L48's Avatar
I wouldn't drive that trailer 1 block without a WDH. Make sure you get one and set up properly. Even dry, that trailer will drop 850 lbs on the hitch. I'd bet that the Tundra's hitch is rated to only 500 lbs without a WDH.
Driving it empty and alone will probably be OK, with a proper WDH, of course.
Not sure what the TV payload is, but the loaded trailer will be putting ~1,000 lbs on the truck. Most 1/2 tons are going to struggle with this kind of load, after adding in passengers, hitches, and other gear. That's a quad-bunk floorplan, so I'm guessing a wife and at least 3 kids?
Filling it up with camping gear and adding the family will not work safely with that Tundra. It will take a specially outfitted 1/2 ton to be able to tow it all and be within specifications (e.g., F-150 3.5 EB Max Tow HDPP).
RV: 2018 Rockwood Mini Lite 2504S
67L48 is online now   Reply With Quote
Old 06-09-2019, 01:21 PM   #6
I suggest you do internet searches on how to properly adjust the wdh. That combination of tv and to makes the setup critical.
Ps you’ll need some good wrenches to do it.
Trksr is offline   Reply With Quote
Old 06-09-2019, 02:32 PM   #7
Also be sure you've got a trailer brake controller in the Tundra and that the trailer brakes work properly. If you need to stop fast you'll want the camler to stop itself. Otherwise it will push you somewhere you dont want to go.
Skip12 is offline   Reply With Quote
Old 06-09-2019, 02:59 PM   #8
HONDAMAN174's Avatar
If you do not have towing mirrors, get them now. You will need to be aware of larger vehicles coming up on your left and then plant your right front tire on the white line in your lane. That will give you the best advantage on not getting sucked in by trucks. I cruise at 60-62 to get best mileage and everyone else can go around. Get gas at truck stops so to have plenty of room being you are 55 ft
Just glad to get away
Old 06-10-2019, 02:07 PM   #9
You likely need a WDH. Unless you have experience setting up a WDH I'd try to make an appt at a nearby RV dealer to set up the WDH. There are a lot of RV places in Florida. I'd also think about staying over at your mother's the first night to make sure its set up right, including the brakes.
Jeff
2016 APEX 215rbk
2016 F-150 4WD 3.55 3.5l ecoboost
jwfrede is offline   Reply With Quote
Old 06-10-2019, 02:27 PM   #10
Pull-throughs
When I travel across country, I reserve pull-through sites in KOAs. Makes it easy to stop for the night and I don't have to unhitch.
micro_jul is offline   Reply With Quote
grey wolf, towing
