We had an 05 Cherokee 28A (no bunk slide). I had a leak that I didn`t know about. no it wasn`t leaking for months and caused damage! i found it after we came home from a trip. I had the trailer pulled into the driveway with the truck in the garage. it started to downpour HARD and with the trailer tilted backward because it was in the driveway different than normal, all the water on the roof rolled in the opposite direction than normal and ran in under a bad seam at the front wall. I had a small river along the wall on the doorside. I found the leak after the rain stopped. I never had any water before this, or after. so I assume I fixed it. maybe that is the problem with your trailer. if the trailer is tilted one way or the other the water leaks in at a bad seam?!
just thought I`de throw this out there, maybe could help.
Good luck!
Kevin
