Old 08-19-2018, 10:21 PM   #1
22rdse limited
Where is the fresh water tank drain located I was told in front of duals but all I got is a red and blue drain with white caps don't think they are right. Any help?
Luke1567 is offline   Reply With Quote
Old 08-19-2018, 10:32 PM   #2
I don't know what a 22rdse is, and you don't mention brand, and there's nothing in your profile; suggest you add this info.
I DO know the red and blue lines are your hot and cold low point drains. Open and drain these when you winterize.
Update: Just realized you posted in the Cherokee section, but that didn't help me much. I googled "Cherokee 22rdse" and got nothing. I did see Cherokee Grey Wolf 22RR's and 20RDSE's.
Looking at outside pics of a 20RDSE on-line, I'd concur it's probably forward of the wheels. Find your FW tank fill and it's probably within a foot or so forward or aft from that point (i.e. somewhere between the back of the bedroom window and the front axle). The tank is typically located with the fill connection, although the connection could be connected to the front, rear, or middle of the tank. In other words, the fill line won't typically run several feet forward or rearward to the tank.
2011 Traverse LT, 3.6L, FWD
