Old 07-14-2016, 06:32 PM   #1
26dbh A/V question
Is there a way to get the television sound to come through the coach speakers? I've hooked the audio cables from the TV audio out into the audio ports by the radio and set the radio to AV in but get no sound. What am I missing?
Moellerdan is offline   Reply With Quote
Old 07-14-2016, 06:39 PM   #2
RND
RND's Avatar
Good question, been wondering the same. Hopefully someone can help out with this one.
Sent from my SM-G930V using Tapatalk
2016 Cherokee 274DBH
2015 Ford Expedition Limited
2015 Polaris RZR 570 LE Trail Edition
2012 Polaris Sportsman 500
2009 Yamaha Yz250f
RND is offline   Reply With Quote
Old 07-14-2016, 07:35 PM   #3
Who Dares, Wins
doc73's Avatar
If you pull the face of the radio off there might be R and L ports behind the radio. I have been toying with the idea of pulling this apart and putting a audio jack onto the wall for this.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 07-18-2016, 07:49 PM   #4
I had the same problem so I pulled out the radio and switched inputs in the back and IT WORKED!!! They had the wires swapped from factory
Loda8383 is offline   Reply With Quote
Old 07-18-2016, 09:06 PM   #5
auxiliary wire from tv to radio. Works well for me.
2016 Grey Wolf 26DBH
Ram 2500 5.7 Hemi 4WD
gconley is offline   Reply With Quote
Old 07-18-2016, 09:07 PM   #6
No need to pull radio . Connection is on the front of the Furrion .
Old 07-18-2016, 09:37 PM   #7
The wires to the AV outputs on wall and outside are on the back of the radio on the 2017 26DBH not sure of other years
