Old 07-25-2018, 10:55 AM   #1
26DBH mini kitchen ice maker drain
We recently purchased a 2019 26DBH and am curious how you drain the ice maker in the mini kitchen? The owners manual shows a drain on the bottom but mine is bolted down so the drain isn't accessible. Do we have to remove the bolts each trip?
JSLayton is offline   Reply With Quote
Old 07-26-2018, 07:03 AM   #2
SeaDog's Avatar
check under the rig and see if there is a drain there
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-26-2018, 07:11 AM   #3
There isnít that I can tell.
Old 07-26-2018, 04:11 PM   #4
I have a similar mini kitchen with the use maker in mine. Yours may be bolted down differently but I can slide my ice maker back then lift it out to drain and then put it back in and slide it up tight.
BdavidS84 is offline   Reply With Quote
26dbh, drain
