Old 09-10-2016, 01:58 PM   #1
26DBH water pump kit for winterization
I bought a Camco winterization kit on clearance yesterday for $10 to install on my water pump for pumping antifreeze through my water system. I assume some have done this. Has anyone run into any issues, or have any suggestions to throw my way before I put this kit on?
Thanks!
2017 Forest River Gray Wolf 26DBH
2005 Ram 1500 Big Horn 5.7L HEMI
Moellerdan is offline   Reply With Quote
Old 09-10-2016, 05:42 PM   #2
I installed same kit last October on my 26 DBH. I moved the water pump just a little for clearance. Ensure you install the valve in correct direction. It's clearly stamped on valve.
ginonut is offline   Reply With Quote
Old 09-10-2016, 06:13 PM   #3
Originally Posted by ginonut View Post
I installed same kit. I moved the water pump just a little for clearance. Ensure you install the valve in correct direction. It's clearly stamped on valve.
X2
modemem is offline   Reply With Quote
pump, water, water pump, winter
