Old 10-14-2018, 10:06 PM   #1
274DBH Camco Winterize Kit Install
I have read all the other threads on installing the kit and access to the pump. Here is what I did...
I took the plywood off the bed above the front storage area so that I could access the water heater and pump. When I went to install the bypass valve I could barely reach the pump. Also there was not enough room between the pump and all the water lines entering the floor area. My pump was installed at a crazy angle as you can see in the picture. The bypass valve and the water screen overlapped.
So I needed to move my water pump but I could not reach the screws holding the pump from the storage area. I had two options, remove the outside shower or create an access at the bottom-front of the wardrobe closet. I decided not to remove the outside shower. I did not know how much hose was available to move it out of the way and I didn't want to have to seal it back up.
So through the front it is...
I really didn't want to cut a hole only to install some form of door or make a panel cover. As you can see above the frame of the bed was built over top of the piece of panel. So I took a sharp razor knife and I scored along side the bed frame. It took about 10 passes and I had cut through the paneling.
Then I slowly pulled off the front panel as it is only stapled on. I took wire cutters and clipped off the back of the staples (I didn't want holes)
Once removed, I moved my pump and finished installing the kit (I also cleaned up all the factories wood and metal shavings they left behind).
I still need to reach the water heater bypass valve as I cannot reach them from the front. So I created an access door from the top of the bed area. I cut and 8"x10" hole. I took two pieces of 1x2 and installed under the hole to create a brace so the piece of wood I cut out will lay flush.
Now I can access the water heater.
I drilled a 1" hole so it is easy to remove.
Now all that was left to do is close the front back up. I used three 1/2" black screws that I had left over from some other project.
And here is the finished project. You can barely see the three screws. Now all I have to do is remove them and I have full access to the pump and winterizing kit.
I camp to burn off the CRAZY!
Somewhere there is a Tiki Bar and a Jimmy Buffett song that needs me...
2019 Cherokee 274DBH
DonD is offline   Reply With Quote
Old 10-14-2018, 10:29 PM   #2
Mch5jdm's Avatar
Nice
Let’s go camping!
Mch5jdm is offline   Reply With Quote
Old 10-24-2018, 07:41 AM   #3
DonD, this post was a huge help. I'm a travel trailer newb but wanted to learn winterizing (from Buffalo). Thanks for posting, followed you step by step. If I could reach through the internet and buy you a beer I would.
canoes, IPAs, campfires, Pilsners, hiking, Oktoberfests....
2018 Cherokee 274dbh
2015 Chevy Silverado Crew Cab
Munro is offline   Reply With Quote
Old 10-26-2018, 01:00 PM   #4
MillMitch's Avatar
Nice job. The whole through the board under the bed is on my spring to-do list. I practically have to crawl into the underbed space to turn the water heater valves to bypass. My water pump is in the bathroom, so that shouldn't be a problem.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 10-26-2018, 09:08 PM   #5
Thanks for the positive comments. I have learned so much from this forum in such a short time, it feels good to give back.
As a side note to the bypass, I had trouble getting it to prime. My solution: I don't pull the seal off the antifreeze, but just stick the hose through it. Then I sorta seal off the hose using my hand between my thumb and index finger (like making an OK sign). I then have my wife turn on the pump and slightly turn on the faucet and I immediately turn the jug upside down. It gets it flowing. Took about 1 and 1/2 gallons to fill lines. I did have to prime each gallon this way. Only a tiny bit dribbled onto the floor. After running pink stuff through all the lines (including outside showers and reliving pressure on city water) I dumped the remaining 1/2 gallon in the drains and toilet. $4.58 well spent.
I already have the winterize blues...
winterize, winter
