Old 04-10-2016, 01:25 PM   #11
What type hooks did you use on the sink mount? Great ideas!
Xrrider is offline   Reply With Quote
Old 04-10-2016, 01:58 PM   #12
The 3m ones. They make all different kinds but I just found one that looked like it came away from the wall and had a long holding arm. They came 1 per pack.
'16 Cherokee 274DBH
'16 F150 XLT Crew 3.5eco
Mike
2016 Cherokee Limited 274DBH
2009 Ford F-150
Michael4017 is offline   Reply With Quote
Old 04-11-2016, 09:56 AM   #13
Name:	ImageUploadedByForest River Forums1460382949.760301.jpg
'16 Cherokee 274DBH
Mike
2009 Ford F-150
Old 04-19-2016, 08:13 PM   #14
Can you tell me more about tv I have been trying to find someway to mount
ffemt721 is offline   Reply With Quote
Old 04-19-2016, 08:27 PM   #15
In the bedroom, I measured the distance between the doors(closed) and cut a spare piece of wood slightly smaller in width and probably about 6" in length. I then drilled two holes through the piece of wood a little smaller than the lag bolts(2.5" in length and decent width). I spray painted the piece of wood black just so it doesn't stick out. Then I used a cheapish tilt mount that fit my tv from Amazon. Click image for larger version
Name:	ImageUploadedByForest River Forums1461111910.102725.jpg
I used 3" lag bolts to secure the mount to the wooden block and the length made it into the wooden backer. Then secure the tv to the mount.
That's what I did.....it works.
'16 Cherokee 274DBH
Mike
2009 Ford F-150
Old 04-20-2016, 05:12 PM   #16
dmacalli's Avatar
Originally Posted by Michael4017 View Post
Sink cover storage using 2 adhesive hooks upside down(saw this in a rv magazine). Attachment 103144
Tv mounted in bedroom-used a piece of wood to keep mount off the wall so the doors can closeAttachment 103145
Padded the bunk ladder using a pool noodle and duct tapeAttachment 103146
'16 Cherokee 274DBH
Hey there ffemt721
As an alternative option, I purchased a wall mount off of Amazon (NBL 100-M Ultra Slim TV Wall Mount) and did not need to worry about attaching any wood, just right on to the wall right between the doors. Worked absolutely great!
ID:	105557   Click image for larger version
dmacalli is offline   Reply With Quote
Old 04-20-2016, 08:29 PM   #17
Name:	ImageUploadedByForest River Forums1461198505.328509.jpg
There's what the mount I ordered looks like.
'16 Cherokee 274DBH
Mike
2009 Ford F-150
Old 04-21-2016, 08:09 AM   #18
dmacalli's Avatar
Attachment 105577
'16 Cherokee 274DBH
Looka great Michael!
Old 05-22-2016, 06:37 AM   #19
Is there a reason to not use a ceiling mount where it's indicated to install on the ceiling in the bedroom?
Jerheye is offline   Reply With Quote
Old 05-22-2016, 06:59 AM   #20
I just thought it wasn't as sturdy as the wall. Plus I don't like making extra holes in the roof area. I'm sure it's personal preference. Plus a wall mount was cheaper(more readily available) than a ceiling mount.
The ceiling mount I purchased was heavier than the tv I wanted to mount. I ended up returning it and purchased my $15-20 mount from Amazon.
'16 Cherokee 274DBH
Mike
2009 Ford F-150
modifications
