Old 09-01-2012, 10:40 PM   #1
28a+ Slide Leak
Hello everyone. I am new to the forum. I just purchased a 2005 28a+ and just Love It........ There is a 6" x 10" area that has had water damage. It is on the lower front corner on the bund slide out. I know water can travel. Where do I start? Thanks
Blinkey is offline   Reply With Quote
Old 09-04-2012, 12:37 PM   #2
Big Dawg's Avatar
Does it have sky lights, that is a common one.
2004 Chevy Avalanche Z66 W/Transmission Cooler
2011 Grey Wolf 28BH
Blue Ox Sway Pro WDH
2 Beagles (Snoopy & Dexter)
Big Dawg is offline   Reply With Quote
Old 09-04-2012, 04:13 PM   #3
No Sky light. The water damage is on the inside, lower, forward corner of the outer wall of the bunk slide-out. Not sure if it is leaking from the slide-out seal when it is closed or from the caulked areas of the slide itself.
Im going to check the seal and re-caulf the seams of the slide -out. Hopefully that will fix the leak. Once I make sure the leak is stopped, i'll then fix the small damaged area.
All thoughts are greatly appreciated.
THANKS
28a
