Old 06-16-2015, 11:20 PM   #1
A/C
26RL Grey Wolf. A/C has run 95% of our camping trip. It's been a scorcher. Unit doesn't quite cool it down but it's tolerable. Noticed at night it brought temp down, shut off maybe 5 seconds came back on for less than a minute. Then did same thing. Next morning as it warmed up it wouldn't come on. Had to turn thermostat completely off, I guess, to reset. It came back on and has done this 3 times. No tripped switch. Any ideas. Thanks.
71ump is offline   Reply With Quote
Old 06-17-2015, 12:29 AM   #2
SKnight's Avatar
Between the rapid AC cycling at night and its general behavior I'd guess the thermostat is acting up.
Old 06-17-2015, 05:39 AM   #3
davel1971's Avatar
if inside temp gets to within 5 degrees of set temp, it shuts down for a few seconds, then comes back on at low fan speed instead of high. Maybe this is what it was doing, changing fan speeds.
David & Lynn
Old 06-17-2015, 09:15 AM   #4
. Thanks. Will get thermostat looked at though.
Old 06-17-2015, 10:31 AM   #5
Ret E-9 Anchor-clanker
donanddona's Avatar
Do you have registers at the AC discharge? Is your AC ducted in the ceiling? I have both, I close the AC registers during the evening hours and open them during the sunny hours. Additionally, we use silver bubble shades on all windows. Your AC maybe freezing over causing a shutdown. I also close all doors during day. Some say your AC will only cool to within 15-20 degrees below outside temps. Stay thirsty myfriend
donanddona is offline   Reply With Quote
Old 09-26-2015, 07:46 PM   #6
I will recommend buying a thermometer that measures between 40 degrees to 150 degrees, or something close. It needs to have a 6" probe also. Check the outgoing air temp at the A/C holding the thermometer there for five minutes. You should have a reading of 52 +/- 2. IF you have ducted air check all registers also for same reading. IF your unit is less than 2 years old and your A/C is a Domestic brand you may have an A/C unit that was undercharged at the factory.
Thurman is offline   Reply With Quote
