Old 04-18-2014, 07:45 PM   #11
Oklahoma Proud
MillerTime's Avatar
Originally Posted by Ford Idaho View Post
The water comes from frost buildup melting from the condenser right?
Evaporator, is what gets cold, shouldn't freeze up though. Condensor handles the hot end of an ac system.
Condensation is from warm air meeting cold, just like in rain storms
MillerTime- Future Sabre Handler!!
Old 04-18-2014, 07:48 PM   #12
Broadway Joe's Avatar
Humidity condenses on the evaporator, and drips outside onto the roof. You wouldn't want it to drip inside.
Broadway Joe is offline   Reply With Quote
Old 04-18-2014, 07:50 PM   #13
Iwannacamp's Avatar
I am pretty sure ALL of these are hermetically sealed. The checking the "freon" level means tapping into the system...or using superheat to check it... If you can someone smart enough to do that. The condensation is normal and is removed on the evaporator from the air in your trailer. Camp on.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 04-18-2014, 07:53 PM   #14
Ford Idaho's Avatar
Ah thank you for the correction.
The trailer is an 2006 I figure the AC had not been serviced.
A plugged filter will cause low or no air flow.
Low Freon will cause less than optimal cooling and over work the unit.
Also if the thermometer was set below 70F?
Old 04-18-2014, 08:03 PM   #15
Temp was 75 'ish. Unit was serviced late last year.
2006 Forest River Cherokee Lite Series M-28A 29' Slide
Dodge Durango Limited, 5.7l Hemi
The Missus, Monkey Boy, Little Bovva and Bogey the Boxer.
tigerbaywarrior is offline   Reply With Quote
Old 04-18-2014, 08:03 PM   #16
Oklahoma Proud
MillerTime's Avatar
True, just OP only mentioned condensation question though.
Old 04-18-2014, 08:07 PM   #17
Todouble's Avatar
You can't check superheat unless you know what the low side refrigerant pressure is. While I've never been into ours I don't know, but I would think that there are refrigerant taps on it. But this does no good to the regular joe without a set of gauges. Condensation running off the trailer is all normal and will vary based on humidity. I see no reason to worry to the op! If it's cooling down your rig and you have condensation running off the roof all is good!
Todouble is offline   Reply With Quote
Old 04-18-2014, 08:12 PM   #18
Ford Idaho's Avatar
Okay after a correction and this information I guess you are good to go.
Thanks to those in the know....
Old 04-18-2014, 11:27 PM   #19
Iwannacamp's Avatar
Oooppss. Sorry I wasn't thinking correctly. No service ports.
2017 Puma 297RLSS
Old 04-19-2014, 12:52 AM   #20
Normal. You know it gets humid in our neck of the woods.
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
