Old 06-28-2015, 12:24 PM   #1
AC electrical question 265dbh
Wondering if I can use my trailer AC when it's connected to my exterior home outlet 110v connected to 20amp breaker?
Astpman is offline   Reply With Quote
Old 06-29-2015, 08:10 AM   #2
JustB_Rad's Avatar
If all that is on it is the Camper on a Heavy Duty Dog bone adapter, you shouldn't have any problems. We do it all the time and nothing even gets warm. I'm also plugging into a 20A GFI outlet. If feel any warmth in your adapter or cords, you're stressing it too much and shouldn't do it. If I happen to plug into the other side of my garage, where our garage refrigerator is plugged in, if the fridge is running, I can't run the AC or it pops the breaker.
JustB_Rad is offline   Reply With Quote
Old 06-30-2015, 12:06 PM   #3
driftinby's Avatar
I've done the same- ran a\c and some lights on a 15 amp circuit without a problem. By design, a 20 or 15 amp breaker will break long before a 30-amp cord heats up.
2014 Ford F150 FX4 EB
2015 Grey Wolf 26DBH
1994 Palomino TXL
driftinby is offline   Reply With Quote
Old 06-30-2015, 12:44 PM   #4
TURBS's Avatar
Are you sure your wiring to the 20 amp breaker is rated @ 20 amps?
"Most" home outlets and wiring is only 15 amp.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 07-02-2015, 10:53 AM   #5
Steelframer's Avatar
Make sure it's wired for 20 amps and don't use an extension cord and you should be fine, I believe a 15 amp is too small to handle the start up on the compressor and might ruin your ac.
TT-2015 Cherokee 274dbh TV-2010 Jeep Commander Limited
Steelframer is offline   Reply With Quote
Old 07-02-2015, 11:40 AM   #6
wmtire's Avatar
I do agree, that by design the circuit breaker will hopefully trip...but this is not always in reality. Depending on my mood, I sometimes just go with the flow and state the same, or sometimes get all 'preachy".......like now.
Everyone "hopes" the circuit breaker will trip if overloaded, but this isn't always the case. I have stated in several of my soap box rants, to please don't place blind faith in a circuit breaker. They go bad, and some are built bad....and they fail many times.
Experts say electrical panels may be a fire waiting to happen | Dallas Morning News
Here is some more reading for everyone to understand what a circuit breaker is actually designed for. You may be surprised:
http://www.electrical-forensics.com/...tBreakers.html
This is speaking from someone who had a small electrical panel fire at my shop several years ago. The panel just happens to be in my office, about ten feet away and I started smelling something burning and it caught fire. If I hadn't been in here, the whole shop may have went up in flames.
That's why I go off on these tangents every now and again
Sorry.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 07-03-2015, 02:07 PM   #7
OntarioFireFighter's Avatar
US Federal Pacific StabLok panels (not to be confused with the Canadian Federal Pioneer) version) and Zinsco panels are basically considered fires waiting to happen these days; and are fairly common some areas of the states...
That said - most breaker's do operate as designed; and if they trip, more often the not, it's because they are doing their job.
As for the OP's question - short answer is "maybe" - it'll depend on the load on the breaker - if the trailer is the only thing on it; should be fine. If the outlet is shared with other 'stuff' in the garage or through the home - maybe not.
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
OntarioFireFighter is offline   Reply With Quote
electric, electrical
