Old 09-25-2014, 06:02 AM   #1
slaslo's Avatar
Air conditioning question
Hello all,
I have a question about the air conditioner for a 2014 gray wolf 26DBH. Is it normal for the ac to run/shut off and 30-45 secs. later cycle back on and run for three minutes and shut off again? Outside temp was low to mid 80's with high humidity. Inside thermostat was set to 74degrees.
Any and help is greatly appreciated
Cheers..
slaslo is offline   Reply With Quote
Old 09-25-2014, 08:57 AM   #2
cdangel0's Avatar
I'm not sure if it's "normal" or not, but considering a thermostat is designed to hold a constant temperatuure, and given the smaller space it's cooking I could see it happening.
Just out of curiosity though - is there a vent near the thermostat that could be blowing cold air on it? I imagine there's a likelyhood of the AC kicking on, blowing cold air on the thermostat making it "think" the whole camper is 74 - once it kicks off it quickly registers it's still too warm in the camper and turns the AC back on, thus repeating the cycle.
Craig & Lynn D'Angelo
Delaware
cdangel0 is offline   Reply With Quote
Old 09-25-2014, 09:07 AM   #3
Mr. Dan's Avatar
Do a search for the word 'cycling' and see what others have done/recommended.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 09-25-2014, 09:07 AM   #4
mud yapster's Avatar
Originally Posted by slaslo View Post
Hello all,
Cheers..
No that isn't normal, that is short cycling the compressor in the A/C unit which isn't good on any A/C unit.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 09-25-2014, 01:08 PM   #5
slaslo's Avatar
Thanks everyone.. I think there may be a vent pointed at the thermostat..
Awesome input.. Thanks
Cheers
Old 09-25-2014, 01:51 PM   #6
Toy-aholic
you could be low on refrigerant and the low pressure switch is kicking the compressor off... or the condenser fan isn't coming on... or air blockage to the condenser and the high pressure switch is kicking the compressor off.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 10-09-2014, 07:25 PM   #7
slaslo's Avatar
Update... The thermostat fan was on Hi.. Switched to auto as well as turner the vent away from stat... Wala..
Seem to be working ok now.. Once we get back into the cooling season I will have a better idea.
Thanks again for the help😄
Old 10-11-2014, 11:35 AM   #8
Jwatty's Avatar
Ok, I've read the manual countless times but can't figure it out....how do you know if it's on auto or not??
Jwatty is offline   Reply With Quote
Old 10-11-2014, 11:53 AM   #9
Ford Idaho's Avatar
Press mode till fan shows, press +\ - for high/low/auto.
If this is your therm.
Old 10-11-2014, 11:54 AM   #10
Mr. Dan's Avatar
I don't know about your manual but the answer is at least implied in post #7 and matches fact on my trailer. I don't know if yours is the same.
Use the mode button (or whatever it's called on your thermostat) to set the unit to Fan... not Cool or Heat. Then use + on the right to cycle through Hi, Lo, Auto.
If that doesn't work, your thermostat is not like mine.
Ford Idaho beat me to it!
air conditioner
