Old 07-04-2012, 11:28 AM   #1
recon33alpha's Avatar
Air ride discussion
Anyone using an adjustable air ride system in the back to help stabalize load? I have 2010 gmc 1500 hd, but would like to add something to help relieve the stress. Give me your pro's and con's, what brands are you using, etc................Thanks in advance.
2010 GMC SIERRA
2012 GREY WOLF 25RR
2012 campouts: 42
2013 campouts:1
recon33alpha is offline   Reply With Quote
Old 07-04-2012, 12:07 PM   #2
MtnGuy's Avatar
Are you using a weight distributing hitch ???
Old 07-04-2012, 01:22 PM   #3
TURBS's Avatar
I recently put Firestone air bags on my silverado 2500hd.
I pull a 36' fifth wheel.
Before just applying breaks made the truck and trailer buck and launch when brakes released.
Now its very smooth.
I had a lot of chucking on certain roads making it uncomfortable.
Now its much more smooth and enjoyable.
Before the truck sat nose high now it level.
My 2 cents
Old 07-04-2012, 01:45 PM   #4
RonLynnJr's Avatar
I installed a set of Air Ride bags and onboard compressor on my 2500 Ram and it makes the world of difference. Plus they had a hundred dollar mail in rebate. The ride is much better when going over not-so-pleasant roads. You will not hardly feel the toungue weight because the bags help to dampen the shock and bouncyness.
Ron, Tami, Annette, and Ron III
United States Coast Guard Active Duty
2011 Salem 28BHSS / 2004 Dodge 2500 Cummins
2012 reserved/camped (17/4)
RonLynnJr is offline   Reply With Quote
Old 07-04-2012, 01:52 PM   #5
My 2 cents
X2 f1100turbo, have had the same set with onboard compressor on the last 3 trucks (1995, 2000 & now 2005 Silverado 1500's). They make a world of difference.
Old 07-04-2012, 03:58 PM   #6
yes I have WD, but still would like a smoother ride....What is chucking?????
2010 GMC SIERRA
2012 GREY WOLF 25RR
2012 campouts: 42
2013 campouts:1
Old 07-04-2012, 05:07 PM   #7
jd-ford-hd's Avatar
Chucking is what some people refer to as the forward and aft jerking of the tow vehicle. I have always called it humping.
"IF IT AINT GOT A MOTOR, I AINT INTERESTED"
jd-ford-hd is offline   Reply With Quote
Old 07-04-2012, 05:12 PM   #8
Supposedly on fifth wheels only.
Old 07-04-2012, 05:44 PM   #9
jdadoug
jdadoug's Avatar
Chuckling
So the airbags help with the chuckling? If so what brand of airbag do you reccomend? I'm on the verg of buying some. jdadoug
"Aint never nuthing easy"
jdadoug is offline   Reply With Quote
Old 07-04-2012, 05:52 PM   #10
I have AirLifts with an onboard compressor.
Old 07-05-2012, 07:12 AM   #11
jd-ford-hd's Avatar
Of all the benefits that air bags might offer, stopping the humping would probably not be one of them. Humping develops at the towed, not the towing vehicle. Air ride on your trailer would reduce humping to a minimum.
Old 07-06-2012, 10:52 AM   #12
I bought the Firestone brand, about 60 bucks more then the Airlift brand, both had great reviews though. They are on the way, can't wait to feel the difference. I didn't get onboard compressor, didn't want to pony up the extra money, plus my mechanical skills are minimal. I'll just air them up and keep track of different PSI's under each situation, loaded with quads or empty.
When you take your trucks in for service, do you let out all air when your TV is being lifted at the frame???
2010 GMC SIERRA
2012 GREY WOLF 25RR
2012 campouts: 42
2013 campouts:1
Old 07-14-2012, 12:16 PM   #13
BigTJohn's Avatar
I have a Ram 1500 w/coil rear springs. Fixing to put air bags in. Where did you purchase?
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 07-14-2012, 12:26 PM   #14
Beg to differ, the air bags do stop the humping effect on the truck and adding shocks on the trailer will eliminate it. I have both and no humping/dolphing or porpoising.
Run an experiment, hook up and do not put air in the bags and tow it on a stretch of highway and then pump the bags up and drive the same road and feel the difference.
Old 07-14-2012, 01:45 PM   #15
TURBS's Avatar
I'm with Dunnnc.
My humping, bumping, porpoising , whatever you want to call it was virtually eliminated with air bags.
It went from uncomfortable to wow!
Old 07-16-2012, 08:43 PM   #16
Sorry BigT, been camping the last 7 days, I got them online at www.streetsideauto.com. They have an ad on here. Instructions said 1 hr or less to install, it took me 3 hr's.
2010 GMC SIERRA
2012 GREY WOLF 25RR
2012 campouts: 42
2013 campouts:1
Old 07-16-2012, 08:48 PM   #17
... Instructions said 1 hr or less to install, it took me 3 hr's.
That's cause you're north of the Mason-Dixon.
Just joking, don't want to start the Civil War again. I've never been able to do anything in the time the instructions say either.
Old 07-16-2012, 10:02 PM   #18
mike06081969's Avatar
I have the Firestone Ride-Rites with on-board compressor and console mounted switch and pressure gauge in my F250. I pull a 40' fifth wheel and the bags make all the difference. While it didn't completely stop the "chocking", it minimized it greatly. The best thing, though, is that the truck rides level now, making it much better to drive at interstate speeds. I inflate the bags to 60-65 psi when towing and keep about 10 psi in them unloaded.
Mike in Tennessee
Former 2 time FR owner
2007 Crossroads Cruiser 30QB Fifth Wheel
2008 F-250 Lariat 4x4 6.4 Powerstroke
Firestone Ride-Rites w/cab control
mike06081969 is offline   Reply With Quote
Old 07-17-2012, 03:23 AM   #19
Namchief's Avatar
I got mine at Leaf Springs, Helper Springs and Suspension Parts | SD Truck Springs They are having a sale enter code JULY20 in the discount and get another $20 off got mine for $269.51 with free shipping and this is for Firestone airbag kit.
Time spent 2012 in TT 32 days so far and 21 Planned days this Fall with mini trips in between
2009 Chevy Silverado 1500
2012 XLR Hyper Lite 27HFS
1999 Yamaha Grizzly
1996 HD Dyna Wide Glide
Namchief is offline   Reply With Quote
Old 07-17-2012, 07:41 PM   #20
Namchief: since you have a TT like me, after the air shock install, did you have to adjust your WDH or did you just put minimum PSI's to help lift your TV alittle. I only need alittle lift, and really don't want to re-adjust my WDH! The problem I have is that I haul my Son's atv in the bed of my truck (need some tie downs in the hauler to haul both quads in the hauler) and my atv in the toyhauler. I haven't hooked up yet and experiemented, but without the Toy's, I think I will only need 10 psi's or less to just lift the truck a bit. I got them more to help the rear suspension and to lessen the fatigue(1/2 ton), hope this makes since, anyone else can chime in as well!!
If you didn't adjust the WDH, could you tell more strain on the bars, when backing or making tight turns with the air bags inflated??
2010 GMC SIERRA
2012 GREY WOLF 25RR
2012 campouts: 42
2013 campouts:1
