Old 11-17-2019, 08:35 AM   #1
Alpha Wolf 2020 Black Tank clogged
Sewer drains but not completely
Bennett is offline   Reply With Quote
Old 11-17-2019, 08:51 AM   #2
Chris Pastuzyn's Avatar
Welcome from New Jersey, Are you relying on the sensors that say the tank isn't empty?
Chris Pastuzyn is offline   Reply With Quote
Old 11-17-2019, 09:08 AM   #3
Had you used the camper and the black tank this past year and kept the black tank drain valve open while attached to the camp site sewage? I'd do you could have stacking if solids in the tank.
Another common black tank drain issue is the hole saw cut out slug that falls into the tank during manufacturing can become lodged into the drain line.
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,075 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,546 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
2019 Kawasaki Mule Pro DX W/EPS and Yanmar Diesel 2,000 LB towing and 1,000 payload.
Larry0071 is offline   Reply With Quote
Old 11-17-2019, 09:45 AM   #4
My tank in my Hathaway is just hard to empty.
I use the geo method and only Scottís rv tissue. Generally we add 3-4 gallons of soapy water from the kitchen sink before making a major deposit in the toilet.
To empty my tank 100% requires I fill it up pretty full. Empty. Add a dedicated line between the clean out inlet to the water source.
Refill the tank 75%. Drain. Usually twice.
Traveling with a partially filled black tank loosens it up.
Sort of a pain, but works.
tomkatb is offline   Reply With Quote
Old 11-17-2019, 10:07 AM   #5
Trailer Park Supervisor
NJKris's Avatar
I would snake it out from the drain pipe in case debris has collected in there. Gonna be gross, but hopefully not too gross since it's such a new trailer, unless you've been using it full time!
NJKris is online now   Reply With Quote
Old 11-17-2019, 10:35 AM   #6
Chuck_S's Avatar
Try this. Got it at Walmart.
https://www.walmart.com/ip/Tank-Blas...SABEgIkdPD_BwE
-- Chuck
Chuck_S is offline   Reply With Quote
Old 11-17-2019, 10:35 AM   #7
wmtire's Avatar
Duplicate threads merged into this one
2011 Flagstaff 831 RLBSS
Words are powerful.
Choose them good.
Old 11-17-2019, 10:58 AM   #8
NJKris's Avatar
Chuck's option sounds better than mine!
Old 11-17-2019, 11:34 AM   #9
D W
D W's Avatar
Not knowing the actual content of your black tank, I would drain off as much liquid waste that is possible. Then I would add a cup of good ol' fashion RID-X with a few buckets of warm water. Let it sit for about 24-72 hrs to allow the enzymes to go to work digesting the solid waste left in the tank. Then attempt a dump.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
black, black tank, tank
