Old 05-16-2016, 07:21 AM   #11
Provided that there is room below your omni, many have updated to a King Jack directional antenna and used the existing roof penetration, coax and dc power. You will have to drill through the liner and attach the rest of the Jack.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-16-2016, 07:26 AM   #12
Flybob's Avatar
Originally Posted by SeaDog View Post
There are many good antenna's on the market that a person can retrofit to the existing hole in the roof.
This may not be the case if you have one of the standard knock off batwing antennas ( See attachment) as they only have a small ( <1/2") hole in the roof itself and do not have a hole in the ceiling as they are fixed and do not have a rotating mechanism.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-16-2016, 07:32 AM   #13
I'm looking at the King Digital HDTV antenna. It's the smaller one that doesn't need to be lifted but rotates 360 degrees. Anyone familiar?
Tngahan is offline   Reply With Quote
Old 05-16-2016, 07:38 AM   #14
Right. My 335DS has the same problem. Another poster responded that he had replaced the fixed omni with the Jack and used the existing hole, cables, etc. Even FR has dropped the omni in favor of the jack for this model year.
2015 335DS
Old 05-16-2016, 07:44 AM   #15
Of course...right after I buy the 2016 model with the Omni. Lol
Old 05-16-2016, 07:45 AM   #16
Flybob's Avatar
The junk Con CA_2500 fixed omni antenna uses a small hole (<1/2")in the roof only for the coax. There is no hole in the ceiling. The King Jack ( a much better antenna) requires a 2 1/2" hole in the roof and a smaller hole in the ceiling. Position is critical as you do not want to damage AC ducts or wiring in the roof.
TST Tire Monitors
2 100W solar panels
Old 05-16-2016, 08:01 AM   #17
Correct. On most installations, the Omni is on center line and the ceiling ducts are left and right of centerline. Of course, the installation of a Jack is not trivial, however, in replacing an Omni it appears to be straightforward.
2015 335DS
Old 05-19-2016, 07:09 AM   #18
Michael4017's Avatar
If anyone does the king jack replacement, let me know how it goes.....video looks pretty straight forward-but no project ever goes like the video(at least for me).
'16 Cherokee 274DBH
'16 F150 XLT Crew 3.5eco
Mike
2016 Cherokee Limited 274DBH
2016 Ford F-150
Michael4017 is online now   Reply With Quote
Old 05-19-2016, 05:58 PM   #19
Do you have the Furrow system in your camper? If so try putting it on auxiliary and then see if the channels will program.
Xrrider is offline   Reply With Quote
Old 05-19-2016, 06:19 PM   #20
This furrion system is not very user friendly......I will have to try that at some point
'16 Cherokee 274DBH
Mike
2016 Ford F-150
antenna
