Old 04-24-2018, 08:55 PM   #1
Mch5jdm's Avatar
Battery disconnect Cherokee Grey Wolf
Wondering if anyone that has a 23DBH or similar model know if a battery disconnect is equipped on this line.
Letís go camping!
Mch5jdm is offline   Reply With Quote
Old 04-24-2018, 09:10 PM   #2
I have the 26DBH which are similar and they donít have a disconnect switch but are easy to install.
leonards is online now   Reply With Quote
Old 04-24-2018, 09:12 PM   #3
Mch5jdm's Avatar
Thanks. I couldnít find one but thought Iíd ask. However, where would you mount one if you had too?
Letís go camping!
Old 04-24-2018, 10:09 PM   #4
bikendan's Avatar
Cherokee trailers are an entry-level trailers and they rarely come with a factory battery disconnect switch.
Equalizer WDH
Old 04-24-2018, 10:13 PM   #5
Youíre an entry level trailer!
But really, $8 off Amazon and 2 min install for a disconnect.
911Fire is offline   Reply With Quote
Old 04-24-2018, 10:22 PM   #6
bikendan's Avatar
Wasn't slamming Cherokees, just pointing out that few entry-level trailers come with a factory battery disconnect switch.
Heck, my 2007 Rockwood Roo didn't have one either but after 2010 they did.
I also added a $6 disconnect switch from Wal-Mart.
Equalizer WDH
Old 04-24-2018, 10:54 PM   #7
rmac04401's Avatar
Iíd like to know what makes a trailer an entry level trailer?
Is it brand or model? Like if you donít drive a bmw or Cadillac but drive a Ford is the ford entry level?
Is it because a trailer is not $75,000 or more make it entry level?
Or if the trailer weighs less than 10,000 lbs does that make it entry level?
I would think an entry level would be a tent! Any thing more than that is an upgrade.
When someone says ďentry level trailerĒ sound sort of snooty and condensending! Not everyone needs a Berkshire!
Just my opinion
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 04-24-2018, 11:34 PM   #8
My Coachmen trailer doesn't have a disconnect switch but the equivalent priced Rockwood does. Not a big deal..easy to add.
Spend the extra few dollars and skip the $8 disconnect switch from Walmart and install a BlueSea marine rated disconnect switch.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 04-25-2018, 04:58 AM   #9
Mch5jdm's Avatar
Thanks. Watched a quick you tube and looks easy. I am thinking of trying to install in the front storage to keep out of the elements.
Oh and I am going to class up my rig with the fanciest switch ever!
Letís go camping!
Old 04-25-2018, 05:29 AM   #10
Walmart only sells entry level switches.
Norcalace is offline   Reply With Quote
Old 04-25-2018, 07:05 AM   #11
Our 274DBH which is nearly identical to the grey wolf 26dbh did not come with one but my husband was able to install one in matter of minutes. On ours there are a couple of pre-drilled holes on the tongue of the trailer that allowed us to do that. Not sure if yours has one as well?
Let's Roll!
AmandaN is offline   Reply With Quote
Old 04-25-2018, 07:17 AM   #12
Flybob's Avatar
Slightly off topic, but still good info:
If your battery is mounted on the tongue of the TT in a battery box, check to see if the box has drain holes drilled in it. The box will have vents in the top that will allow water to enter the box. The box does not come with drain holes and very few dealers add them.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-25-2018, 10:49 AM   #13
bikendan's Avatar
Just my opinion
You are misunderstanding my post.
Entry-level trailers have less features than higher-level trailers. Some things that are options, may be standard on a higher-level trailer.
A factory battery disconnect switch is an example.
Equalizer WDH
Old 04-25-2018, 11:21 AM   #14
Haha I get, I agree theyíre entry level in a lot of ways. We just wanted good quality for under 20k and found the Cherokee to fit our needs. Weíre definitely happy with it, but weíve also added about 1500 worth of upgrades to it that the more expensive rigs may have come with.
Old 04-25-2018, 11:29 AM   #15
My "entry level" Cherokee wolf pack toy hauler came with a battery shut off switch inside under the fridge.
2019 Silverado 1500
No camper, currently
polishdon is offline   Reply With Quote
Old 04-25-2018, 11:36 AM   #16
MillMitch's Avatar
Ok, I'm gonna ask the newbie question. My TT is in storage (not at house) and i pull the battery and keep it in my basement. Why would i need a battery disconnect switch? Or maybe i should ask, do i need a battery disconnect switch?
thanks,
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 04-25-2018, 12:46 PM   #17
Mch5jdm's Avatar
Got a picture of where? Sounds like a nice spot.
Letís go camping!
Old 04-25-2018, 12:49 PM   #18
Mch5jdm's Avatar
thanks,
For me I camp 6-10x per year. The rest of the summer itís in the drive connected to the house. If I donít plug it in then Iím about a week my CO2 director is beeping low battery. I donít mind having shore power if DW hasnít nearly cut the extension cord 2x.
This way I just click and disconnect.
Letís go camping!
Old 04-26-2018, 07:09 AM   #19
You might have to zoom in to see all the pre-drilled holes that are in the frame but the arrow points to where the battery disconnect was inserted.Click image for larger version
Let's Roll!
Old 04-26-2018, 06:27 PM   #20
Mch5jdm's Avatar
You might have to zoom in to see all the pre-drilled holes that are in the frame but the arrow points to where the battery disconnect was inserted.Attachment 169596
Thank you. I found that I have the same holes and will do the same. Thanks.
Letís go camping!
battery, battery disconnect, cherokee, grey wolf
