Old 04-01-2016, 06:42 PM   #11
Thank you everyone! I will go out there tomorrow and look for a switch under my propane tanks. In the mean time, how do I get this battery back up to charge? Do I need a battery charger? I know they are deep cycle batteries but I am new to this. Is there possibly a power inverter on it? If I hook it up to a 30 amp circuit will that charge the battery in any way? Thanks so much for yalls help. If there is no battery disconnect switch, I will order one and install it. In the mean time, I will disconnect the battery.
Brandon_rss18 is offline   Reply With Quote
Old 04-01-2016, 06:46 PM   #12
TURBS's Avatar
Can you plug it in now ?
If yes plugging it in will charge battery via the converter
Old 04-01-2016, 06:50 PM   #13
Thanks Turbs. So the TT should charge while its hooked up to main power? I am actually going to install a 30 amp breaker and recepticle tomorrow here at home. Our first trip is in 2 weeks and i will bring it home next weekend and have it hooked up for an entire week before leaving.
Old 04-01-2016, 07:09 PM   #14
Blackhat6mike's Avatar
Yes, it will charge anytime it is connected to shore power.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 04-01-2016, 07:20 PM   #15
Unhook the battery
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 04-01-2016, 07:28 PM   #16
TURBS's Avatar
Now you know the proper way to wire a 30 amp outlet for a camper right?
Old 04-01-2016, 07:32 PM   #17
bikendan's Avatar
Pretty sure that yours doesn't come with one from factory.
All RVs come with power CONverters, not INverters.
Only some Motorhomes and a few 5th wheels come with factory installed INverter.
Yes, unless you drained the battery past its recovery point, plugging into shore power will allow the CONverter to recharge it.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-01-2016, 07:34 PM   #18
30 amp 120 BUS correct? My brother in law is an electrician and he is going to come help me with it. I am a Process Operator. Give me chemicals and I can do something with them. Give me electricity, and I can set a house on fire. Lol
Old 04-01-2016, 07:37 PM   #19
Found this
http://www.myrv.us/Imgs/PDF/30-amp%20Service.pdf
Old 04-01-2016, 07:44 PM   #20
TURBS's Avatar
Good yes!
