Old 10-16-2011, 05:51 AM   #21
Herk7769's Avatar
Originally Posted by dnaraG_1M View Post
Battery lead goes under TT from battery....???
cheers,
johnd
John, within 18 inches of your battery is a red rubber covered current limiter It has two threaded posts with terminal wires on it.
The wires get corroded and show "open" or they trip and need to be manually reset.
I will try and upload a photo.
HAM CALLSIGN - KC3FFW
Old 10-16-2011, 07:19 AM   #22
Wanna Be Camper
SaskCampers's Avatar
John,
You should also find a good old household square junction box somewhere under the nose of the unit basically what f1100turbo was talking about. In there you will find a disaster of mega proportions as far as wiring if it is anything like ones I have seen. All maretted together and some only half tight. If Herks suggestion does not pan out look for the above. Also the brake switch can do you in as well except it would be draining your battery not stopping power from reaching the interior.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 10-16-2011, 01:31 PM   #23
Problem Solved!!
A neighbor's boy agreed to help, crawled under the
TT & found the problem. [Proving not ALL teens are
a royal PITA. Some are friendly, helpful and decent
folks. Kinda like his parents...]
At any rate, he found a j-box and an auto-reset
breaker bolted to a C frame member. Showed him
how to use the multimeter and we verified the fact
that the Auto-Reset breaker had morphed into a
No-Reset Breaker! Picked up a new one and Jimmy
installed it.
I now have DC power inboard the TT. Hurrah......
Full 12 volts with minimum drop. Double Hurrah.
Please allow me to express my gratitude to him and to
all the folks here who helped get me on the right track.
I do thank you, muchly.
Now on to the next dern thing.........
Trailerus Rottenus Expremus.....ugh.
happy weekend.
johnd
dnaraG_1M is offline   Reply With Quote
Old 10-18-2011, 06:30 PM   #24
sherdep's Avatar
glad to hear ya got it fixed
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
battery
